Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe
Old 11-21-2010, 12:01 PM
valmet58 is on a distinguished road
Thumbs down threading with mach3
I tried threading with mach3 wizard (Simple threading lathe v1.17)
lathe set up: -X removes stock -Z is toward head stock
everything starts ok except to the point where the cutter is supposed to retract
at the end of the pass..instead of backing out is goes inward..what could be the problem..Any help appreciated thanks..
Andy
Old 11-21-2010, 12:26 PM
M250cnc's Avatar
M250cnc is on a distinguished road
In diameter mode at X100 the tool is at 100 mm at 0 the X tool is at zero and you will very rarely need to go into a minus number with the X axis
Phil
Sent from my HTC Desire using Tapatalk
Differences Between Mach3 Mill and Mach3 Plasma? cjjonesarmory Mach Plasma / Laser 0 11-18-2010 09:12 AM
Need Help!- Threading ??? freemen General Metal Working Machines 3 10-21-2010 06:57 AM
Need Help!- threading heilcnc Mach Lathe 1 05-05-2010 07:19 PM
g76 threading help panaceabea General Metalwork Discussion 7 01-31-2010 04:32 AM
Help with ID NPT Threading whiteboy Haas Lathes 4 01-19-2009 09:46 AM
