Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe
Old 09-26-2010, 04:24 AM
joao.leite is on a distinguished road
.dxf to g-code Problems
Hi!
I've a very simple shaft designed in .dxf format (attached to this message)
When I try using LazyTurn to open the .dxf I get the following errors:
1. Warning: there's no appropriate default turning profile was found
2. CLazyTurnView: An OpenGL error occurred: invalid value
So, because I was getting nowhere using Lazyturn, I turned to Mach3 import of a .dxf file. By using that, Mach load my .dxf, says it has 1 layer 0 entities... The generated .tap file only contains:
(File ShaftAngled.tap )
(Sunday, September 26, 2010)
G90G80G49
G90.1
G0 X1.0000
M5M30
I'm feeling I'm really a newbie on this. Could someone PLEASE help?
Old 09-26-2010, 04:40 AM
holbieone's Avatar
holbieone is on a distinguished road
can't find any Geometric Statements , at least not in a layer
Old 09-26-2010, 07:36 AM
ger21's Avatar
I don't have any programs that can open that .dxf, and looking at it in Notepad, I don't see any entities in it.
Lazyturn is very specific in it's .dxf requirements. See the manual.
http://www.machsupport.com/forum/ind...1.new.html#new
Old 09-26-2010, 10:33 AM
ooooooook
ok, I see the problem might be with the .dxf itself. I'm gonna review the .dxf generation setup. And I'm gonna have a view at that Lazy manual.
Thanks for your help!
Old 09-26-2010, 10:48 AM
neilw20's Avatar
neilw20 is on a distinguished road
ACAD complains.....
Unknown value "AC1024" encountered in drawing version.
Invalid or incomplete DXF input -- drawing discarded.
If ACAD can't read it's native format, then LazyTurn will sure get confused, or should.
Old 10-04-2010, 01:33 PM
Thanks!
Thank you all for your help.
I've been trying around with some CAD software, but now I think I'll stay with Freecad or CADuntu that just found (for free). They are generating .dxf files that Lazyturn or Mach3 understand.
G code problems, any help appreciated mike hide G-Code Programing 6 01-29-2008 12:54 PM
Couple of EMC2 G-code problems. MagooT Post Processors for MC 11 12-26-2007 11:27 AM
Having problems posting code. Stampede BobCad-Cam 3 10-27-2007 11:18 AM
Help - Problems with Z coordinates in g code Socalsurferx G-Code Programing 4 03-12-2006 04:12 AM
Problems running G-code milgo Mach Software (ArtSoft software) 4 10-31-2004 10:27 AM
