Hi, We about to build a new CNC lathe similar to this one. YouTube- The CentauroT90 CNC AUTOMATIC COPY LATHE DEMO VIDEO for bats Im looking into the CNC side of it at the moment. I have a demo copy of Mach3 Turn, Lazy Cam, Autocad 2000i and solid works 2004. I am writing the programs in autocad then exporting as a .dxf to lazy cam which converts them to .tap from there I load them into mach3. When i write programs which are made up of straight lines everything is ok and mach3 simulates it correctly. However as soon as i try to get it to machine a curve it all goes bad. The drawing in Autocad looks like this:![]() then when i upload it to lazy cam then to mach3 it end up like this When I draw a straight line drawing it looks like this in Mach3 Im not sure what im doing wrong, i just cant seem so be able to simulate a arc. Any help would be greatly appreciated.Thanks, Lachie G |
| Try using LazyTurn instead of LazyCAM. http://www.machsupport.com/forum/ind...0;attach=20331 http://www.machsupport.com/forum/ind...oard,73.0.html
| Thanks a lot for that, i have installed it but when i try to upload my .dxf files into it i get an error "Warning, no appropiate turning profile was found." That happens when i try to upload a .dxf file which has curves. When i import a .dxf file with no curves it opens fine im just unsure on how to export as a .tap file for Mach3. Thanks a heap, Lachie G |
| See Appendices B and C in the manual. http://www.machsupport.com/forum/ind...1.new.html#new
| Huge Problem with Turning Arcs HELP | Cartierusm | Dolphin CADCAM | 12 | 06-10-2009 07:40 PM |
| Load Mach3 point clouds into AutoCAD | ger21 | Autodesk Software (Autocad, Inventor etc) | 0 | 03-04-2007 02:31 PM |
| Fanuc 10M feed problem in arcs | AMEG CNC | Fanuc | 4 | 02-07-2007 05:58 AM |
| lines-arcs vs spline problem | metlcutr55 | General CAM Discussion | 1 | 07-07-2006 10:16 AM |
| AutoCad To Mach2 massive arcs circle. dont know what to do | bdesh123 | Mach Software (ArtSoft software) | 2 | 04-12-2005 07:38 PM |
