Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe
Old 04-06-2010, 06:01 PM
ianober is on a distinguished road
Mach Turn and SolidCAM
I am going to be using SolidCAM with my CNC lathe conversion so I wanted to find out any tips and tricks that anyone has that is already using this combination. I know that SolidCAM does not have a post processor for Mach3 which is not fun but I guess I will have to find a way to work around that problem. Also I have been trying to figure out machine setups and what is the best mode, such as diametric or radial in Mach. So please, feel free to post you little pearls of wisdom here!
Old 04-11-2010, 06:26 PM
Does anyone know the default setting in SolidCAM as far as whether it outputs measurements in radius or diameter mode? I am trying to make sure my setup is correct. I made some test cuts but have not been able to determine if the settings are right.
Need Help!- Turn-Mill posprocessors for Solidcam maparkopo SolidCam 1 11-04-2009 01:46 AM
Mach 3 Postprocessor for SolidCam Debos Screen Layouts, Post Processors & Misc 3 06-20-2008 05:15 PM
Solidcam turn-mill postprocesor fanuc costR Post Processor Files 9 12-10-2007 02:40 PM
Mach 3 and SolidCAM....anyone doing this? ClemsonGirl Machines running Mach Software 6 05-24-2007 01:57 PM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
