Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe
Old 04-04-2010, 06:06 PM
Gold Member
heilcnc is on a distinguished road
better lathe manual
i just started using mach3 turn been using mill for years have very little
trouble with it and can find most help in the documentation that
they wrote for it but the turn leaves a lot out is there better out there
like videos to set tools and can you make the axis travel more off your
home switches after it hits them some times mine does not move enough
still triggered and on the tool setting i need help it does not change my
tool table when i hit touch x or z i need videos like they have for mill ! thanks
Old 04-09-2010, 07:33 PM
Gold Member
is there just not many people using mach 3 turn the mill software is great
but the lathe does not have much support the manual does not go into
much so where do you go
Old 04-11-2010, 06:29 PM
ianober is on a distinguished road
I am having the same problems, I think the best source is just searching forums. I suppose you could try and email Art-soft directly but I doubt they would be super responsive.
manual lathe convert cnc/manual lathe kakayo Vertical Mill, Lathe Project Log 3 02-21-2010 01:13 PM
How to convert Manual Lathe to CNC Lathe? zaid General Metal Working Machines 4 02-07-2008 12:42 AM
Thoughts on a Manual/CNC lathe squarewave CamSoft Products 3 03-20-2006 05:41 PM
Zubal Lathe Manual Kevin Taylor General Metalwork Discussion 0 01-28-2006 09:02 PM
manual lathe 723 General Metal Working Machines 1 04-29-2004 01:32 AM
