Need Help .. VB Script Z Zero
Results 1 to 11 of 11
Thread: Need Help .. VB Script Z Zero
    Feb 2017
    Thailand
    Default Need Help .. VB Script Z Zero
    Hi Everyone
    I use the script for z zero with my digitize probe.
    My problem is when i debug with step by setp this scrip is work then i save in to image button but when i click the button it work but z is incorrect position.
    When G31 Z-20 then probe hit work piece DRO is not set to Zero.
    This is the script
    Rem VBScript Edge FinderIf GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty
    Code "(Probe plate is grounded, check connection and try again)"
    Else
    FeedCurrent = GetOemDRO(818)
    Code "G4 P1"
    Code "G90 F200"
    Rem Z Zero
    DoOEMButton(1010)
    code "G31 Z-20 F100"
    While IsMoving()
    Wend
    DoOEMButton(1010)
    code "G4 P2"
    code "G1 Z1"
    Code "(Z axis is now Zeroed)"
    End If
    This pic i use step by step z is correct position
    Need Help .. VB Script Z Zero-img_20171215_205420-jpg
    This pic i run by click button
    Need Help .. VB Script Z Zero-img_20171215_205433-jpg
    Need Help .. VB Script Z Zero-image-5517-png
    And i tried to Change G4 P100 it not set z zero.
    Now i no have idea about that.....
    I'm a new baby for script....
    Thank you for help.
    Attached Thumbnails Attached Thumbnails Need Help .. VB Script Z Zero-img_20171215_205420-jpg   Need Help .. VB Script Z Zero-img_20171215_205433-jpg   Need Help .. VB Script Z Zero-image-5517-png
    Mar 2003
    Default Re: Need Help .. VB Script Z Zero
    parallel port, or motion controller?
    Which version of Mach3?
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Feb 2017
    Thailand
    I used
    Mach3Version D1.90.038
    And Parallel port
    Mar 2003
    Try this:
    Else
    Code "G4 P1"
    Code "G90 F200"
    Rem Z Zero
    DoOEMButton(1010)
    Sleep(200)
    While IsMoving()
    Sleep(10)
    Wend
    DoOEMButton(1010)
    Sleep(200)
    code "G4 P2"
    code "G1 Z1"
    While IsMoving()
    Sleep(10)
    Wend
    End If
    Feb 2017
    Thailand
    Thank you Gerry
    I'll try and get the result to you again.
    Feb 2017
    Thailand
    Quote Originally Posted by ger21 View Post
    Try this:
    Else
    Code "G4 P1"
    Code "G90 F200"
    Rem Z Zero
    DoOEMButton(1010)
    Sleep(200)
    While IsMoving()
    Sleep(10)
    Wend
    DoOEMButton(1010)
    Sleep(200)
    code "G4 P2"
    code "G1 Z1"
    While IsMoving()
    Sleep(10)
    Wend
    End If
    That work !!!!!!
    So thank you so much Gerry.
    Can you explain why my code not work.
  7. #7
    Mar 2003
    I don't know for sure, but you are using a very old version of Mach3, which requires a Sleep(10) inside the While..IsMoving(). This is not required in later releases of Mach3.
    Also, I added a Sleep(200) after DoOEMButton(1010), to give the DRO's time to update before proceeding.
    And you were missing a While...IsMoving() after the last G1 move. These are required after all movement.
  8. #8
    Feb 2017
    Thailand
    i have a other question..
    What is the type of input text?
    If i want to use text for calculation position.
    Else
    XCurrent = GetDro(0)
    YCurrent = GetDro(1)
    ZCurrent = GetDro(2)
    Code "G4 P1"
    Code "G90 F200"
    Rem Z Zero
    DoOEMButton(1010)
    Sleep(200)
    While IsMoving()
    Sleep(10)
    Wend
    DoOEMButton(1010)
    Sleep(200)
    code "G4 P2"
    code "G1 Z1"
    While IsMoving()
    Sleep(10)
    Wend
    Rem Probe X CENTER
    PART_L = GetuserDRO(9000) <<<<<<<<<<<<< i don't know what is the type of this for get data from input
    PART_W = GetuserDRO(9001)
    PART_T = GetuserDRO(9002)
    DoOEMButton(1008)
    sleep(200)
    XMov1 = (PART_L * 0.5) + 10
    Code "G1 X" &XMov1
    While IsMoving()
    Sleep(10)
    Wend
    Code "G1 Z-4"
    While IsMoving()
    Sleep(10)
    Wend
    Code "G31 X-10"
    While IsMoving()
    Sleep(10)
    Wend
    XPos1 = GetDRO(0)
    Code "G1 X10"
    While IsMoving()
    Sleep(10)
    Wend
    Code "G1 Z1"
    While IsMoving()
    Sleep(10)
    Wend
    Code "G1 X0"
    While IsMoving()
    Sleep(10)
    Wend
    XMov2 = (PART_L * 0.5) - 10
    Code "G1 X" &XMov2
    While IsMoving()
    Sleep(10)
    Wend
    Code "G1 Z-4"
    While IsMoving()
    Sleep(10)
    Wend
    Code "G31 X10"
    While IsMoving()
    Sleep(10)
    Wend
    XPos2 = GetDRO(0)
    Code "G1 X-10"
    While IsMoving()
    Sleep(10)
    Wend
    Code "G1 Z1"
    While IsMoving()
    Sleep(10)
    Wend
    Code "G1 X0"
    While IsMoving()
    Sleep(10)
    Wend
    Code "(X DATA COMPLETED)"
    Rem Probe Y CENTER
    DoOEMButton(1009)
    YMov1 = (PART_W * 0.5) + 10
    Code "G1 Y" &YMov1
    While IsMoving()
    Sleep(10)
    Wend
    Code "G1 Z-4"
    While IsMoving()
    Sleep(10)
    Wend
    Code "G31 Y-10"
    While IsMoving()
    Sleep(10)
    Wend
    YPos1 = GetDro(1)
    code "G1 Y10"
    While IsMoving()
    Sleep(10)
    Wend
    Code "G1 Z1"
    While IsMoving()
    Sleep(10)
    Wend
    code "G1 Y0"
    While IsMoving()
    Sleep(10)
    Wend
    YMov2 = (PART_W * 0.5) - 10
    Code "G1 Y" &YMov2
    While IsMoving()
    Sleep(10)
    Wend
    Code "G1 Z-4"
    While IsMoving()
    Sleep(10)
    Wend
    Code "G31 Y10"
    While IsMoving()
    Sleep(10)
    Wend
    YPos1 = GetDro(1)
    code "G1 Y-10"
    While IsMoving()
    Sleep(10)
    Wend
    Code "G1 Z1"
    While IsMoving()
    Sleep(10)
    Wend
    Code "(Y DATA COMPLETED)"
    Rem MOVE To X0Y0
    XPos_Cen = (XMov1 + XMov2)/2
    YPos_Cen = (YMov1 + YMov2)/2
    Code "G1 X" &XPos_Cen
    While IsMoving()
    Sleep(10)
    Wend
    While IsMoving()
    Sleep(10)
    Wend
    Code "G1 Y" &YPos_Cen
    While IsMoving()
    Sleep(10)
    Wend
    Code "(X Y axis is now Zeroed)"
    DoOEMButton (1008)
    DoOEMButton (1009)
    Sleep (200)
    Code "(READY)"
    Code "F" &Feedcurrent
    End If
    Need Help .. VB Script Z Zero-image-5519-png
    Attached Thumbnails Attached Thumbnails Need Help .. VB Script Z Zero-image-5519-png
  9. #9
    Mar 2003
    GetUserDRO() will return a Variant I think, which can be used in calculations. If you want to use your calculated value as a string at any point, you'll need to convert it to a string first. But you can use the returned value as is.
  10. #10
    Feb 2017
    Thailand
    Thank for fast reply..
    How can i convert it.
    And I try to input value when i press enter it not get my value in dro...it set to 0 .
    Need Help .. VB Script Z Zero-image-5522-png
    Need Help .. VB Script Z Zero-image-5521-png
    Thank you for help
    Attached Thumbnails Attached Thumbnails Need Help .. VB Script Z Zero-image-5522-png   Need Help .. VB Script Z Zero-image-5521-png
  11. #11
    Mar 2003
    You're leading digits needs to be at least 2, to display 50.
