Monitor water cooling of spindle
Results 1 to 3 of 3
Thread: Monitor water cooling of spindle
    Registered slipery's Avatar
    Oct 2006
    Default Monitor water cooling of spindle
    I need to write a Macro Pump ( I think) to monitor fluid flow from 2.2 KW water cooled spindle. ( I want to stop or pause machine if water flow is interrupted from the spindle). I have the circuit designed and constructed so that I get a True/False signal to one of the inputs of my BOB but I don't know how to use the info to stop the router.
    The Artsoft tutorial is fairly limited and I was hoping some one can direct me to a better (more advanced) tutorial on using scripts and macros in Mach3. If not perhaps a kind person could tell me how to do it.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Monitor water cooling of spindle
    Something like this:
    If IsActive(Input1) then
    DoOEMButton(1001)
    Save as Macropump.m1s in the proper macro folder, and enable macropump in general config.
    http://www.machsupport.com/wp-conten...o_Prog_Ref.pdf
    Mach3Wiki
    UCCNC 2017 Screenset
    Oct 2006
    Your a gentleman and a scholar thank you very much. Exactly what I was looking for especially the macro referance
    Cheers
