I have the blue screen setup from bigtex and I have a small issue - after a tool change my job z setting is off by 0.05" in the positive and I'm not sure what setting to adjust to fix it. It taps off the movable plate (0.5" thick and set up in the macro) and then the fixed plate - and when it goes to cut its off by 0.05" (cutting too shallow). Thanks in advance for your help.
