Gday, first of all, thanks in advance. For someone handy with script this is a simple thing, I am not handy with script!
The guy who made my CNC has written this script for the tool changer which has tool forks mounted along the Y axis (which all work) , however I've added a new rack of tools along the Y axis.
When I add the new tool positions, the machine can pickup the new tool, however the script makes the machine remove it from the hook/clamp/fork moving along the X axis, however the new tools need to move along the Y to load & unload
I cannot figure out how to make this happen.
Please help!
'ToolChange Macro For Bed type tool changer 11/05
Sub Main()
OldTool = GetOEMDRO (1200) 'Tool In spindle DRO You must add this to your settings screen
x = GetToolChangeStart( 0 )
y = GetToolChangeStart( 1 )
z = GetToolChangeStart( 2 )
a = GetToolChangeStart( 3 )
b = GetToolChangeStart( 4 )
c = GetToolChangeStart( 5 )
tool = GetSelectedTool()
NewTool = tool
'Tool Changer Macro (Bed Type)
MaxToolNum = 7 'Max number of tools for the changer
ToolDown = -153.8 'Z Pos to Get or drop a tool (NOT USED)
ToolUp = -80. 'Z Hieght to Rapid from tool to tool
If NewTool = OldTool Then
Exit Sub
End If
While OldTool < 1
OldTool = 1
Wend
While NewTool > MaxToolNum
NewTool = Question ("Enter New Tool Number up to " & MaxToolNum)
Wend
Code "G90"
Code "M05"
Code "G00 G53 Z-5.0"
Code "G00 G53 X60.0"
While IsMoving()
Wend
Call MovePosPrep(OldTool)
While IsMoving()
Wend
Code "G4 P1"
Code "G01"
Code "G91 X-50.0 F600."
Code "G4 P1"
Code "G90"
While IsMoving()
Wend
ActivateSignal(Output2) 'Turn On Draw bar to release the tool
Code "G4 P4" 'Wait for the tool to release
'SystemWaitFor (7) 'Wait for the tool Release Limit switch
Code "G00 G53 Z" & ToolUp
Call MovePos(NewTool)
While IsMoving()
Wend
Code "G4 P1"
While IsMoving()
Wend
DeActivateSignal(Output2) 'Turn Off Draw bar to Clamp the tool
Code "G4 P4" 'Wait for the tool to Clamp
Code "G01"
Code "G91 X50.0 F600."
While IsMoving()
Wend
Code "G90"
While IsMoving()
Wend
Call SetUserDRO (1200,NewTool)
SetCurrentTool( NewTool )
Code "G90"
Code "G43 H" & NewTool
While IsMoving()
Wend
End Sub
Sub MovePosPrep(ByVal ToolNumber As Integer)
Select Case ToolNumber
Case Is = 1
Xpos = 52.80
YPos = 314.50
ZPos = -155.1
Case Is = 2
Xpos = 53.30
YPos = 475.00
ZPos = -155.4
Case Is = 3
Xpos = 52.80
YPos = 633.80
ZPos = -155.00
Case Is = 4
Xpos = 51.80
YPos = 793.80
ZPos = -155.20
Case Is = 5
Xpos = 52.10
YPos = 953.90
ZPos = -154.70
Case Is = 6
Xpos = 52.90
YPos = 1114.60
ZPos = -155.90
Case Is = 7
Xpos = 52.90
YPos = 10
ZPos = -155.90
End Select
Code "G53 X" & XPos & " Y" & YPos
Code "G53 Z" & ZPos
End Sub
Sub MovePos(ByVal ToolNumber As Integer)
Case Is = 1
Xpos = 2.80
YPos = 314.50
ZPos = -155.10
Case Is = 2
Xpos = 3.30
YPos = 475.00
ZPos = -155.40
Case Is = 3
Xpos = 2.80
YPos = 633.80
ZPos = -155.00
Case Is = 4
Xpos = 1.80
YPos = 793.80
ZPos = -155.20
Case Is = 5
Xpos = 2.10
YPos = 953.90
ZPos = -154.70
Case Is = 6
Xpos = 2.90
YPos = 1114.60
ZPos = -155.90
Case Is = 7
Xpos = 2.90
YPos = 10
ZPos = -155.90
End Select
Code "G53 Z" & ZPos
End Sub
Main
