Without a license, Mach3 in Demo mode will only display 500 lines of g-code. This is likely the issue that you are seeing.
Hello guys! .
Im new in cnc world- learning stuff step by step-.
i did build router and now learning how things works with mach3 and Fusion360
The problem i cant solve it:
In Fusion i did made simple box with couple holles 10 pcs - and in fusion360 cam fixed to 2d adaptive cleaning, - in fusion all was fine, simulation ect without problems
The GCode i got from fusion and load it to mach3- problem.!!!
Mach3 shows only 1 or 2 holes and not all like need to be in code.
Did run program to see what will happens... one hole was cutted like need to be.. second one start to work and on half programs end.
Same problem i have also with 2d pocket-
Any sugestion what i have any wrong setup- something wrong im doing in fusion?
Thanks for help.
UCCNC 2017 Screenset
Problem solved... Licence file isnt on right place .. thanks- Ger21
