Need Help! usb power problem
Results 1 to 2 of 2
Thread: usb power problem
    Oct 2017
    Default usb power problem
    I have a new installation and I'm trying one stepper motor first. I have Mach3 on windows 10 with a usb cable going a UC100 motion controller (not Chinese) connected to an ST-V2 breakout board. I have a 15 volt power supply to the breakout board. I have all the wiring correct (triple checked) and have pins 2 and 3 selected for the x drive. I get no motor action. No voltage to the DIR or PUL when I try to jog the motor. Both lights are on, on the back of the UC100. I'm not getting 5 volts from the PC5V breakout board connection that feeds the stepper controller. Not sure what to do. Any help would be appreciated.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: usb power problem
    As I said on the Machsupport forum, you need to plug a USB cable into you breakout board to provide the 5V power it needs.
    UCCNC 2017 Screenset
usb power problem
usb power problem
