Spindle not rotating?
Results 1 to 8 of 8
Thread: Spindle not rotating?
    Jan 2016
    Default Spindle not rotating?
    First off lets just pretend I dont know jack about CNC/Mach3 as I just started my journey! However I am no dummy haha
    My issue is this, I have built my first machine which I use for pool cues (X/Y/Z/A-Spindle) I only run two profiles in Mach one for inlays (XYZA A being for indexing rotation) and a Tapering profile where A switches to a spindle job just to turn wood stock (no high RPM and yes I am using a stepper to spin) problem is I can't get the stepper to spin in tapering mode as a spindle. Everything works in the Inlay profile, and in tapering I can disengage the spindle and reactivate A and turn it with a hotkey fine. I have confirmed my settings with others that run the same setup and they all seem to match.
    If you have any ideas please feel free to dumb them up a bit! Haha
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Spindle not rotating?
    Post all of your settings.
    UCCNC 2017 Screenset
    Jan 2016
    Quote Originally Posted by ger21 View Post
    I'll grab what I can tomorrow, is there a file that stores the settings that I can post or am I stuck with screen shots?
    Jan 2016
    Hummm won't let me attach an xml? so I will try screen shots of my applicable settings pages...
    Attached Thumbnails Attached Thumbnails Spindle not rotating?-glc-jpg   Spindle not rotating?-psas-png   Spindle not rotating?-mo-png   Spindle not rotating?-ss-png
    Spindle not rotating?-mts-png
    Jan 2016
    Also the only thing checked active on the input/output/encoder is e-stop
    As I was told and shown by everyone that is correct for this simple setup?
    I am running windows 10, smoothstepper, Xylotex
    Mar 2003
    Shelby Township
    What does your g-code look like? Do you have an M3, and an S### in it?
  7. #7
    Jan 2016
    Here is an exapmle of one of the runs for tapering...
    M3 S800
    M1
    N1 G01 X1. Y0.0048 Z0. F4
    N2 X2. Y0.0108
    N3 X3. Y0.0190
    N4 X4. Y0.0263
    N5 X5. Y0.0360
    N6 X6. Y0.0453
    N7 X7. Y0.0543
    N8 X8. Y0.0655
    N9 X9. Y0.0773
    N10 X10. Y0.0860
    N11 X11. Y0.0973
    N12 X12. Y0.1065
    N13 X13. Y0.1140
    N14 X14. Y0.1200
    N15 X15. Y0.1263
    N16 X16. Y0.1303
    N17 X17. Y0.1340
    N18 X18. Y0.1390
    N19 X19. Y0.1425
    N20 X20. Y0.1490
    N21 X21. Y0.1540
    N22 X22. Y0.1580
    N23 X23. Y0.1590
    N24 X24. Y0.1620
    N25 X25. Y0.1645
    N26 X26. Y0.1660
    N27 X27. Y0.1670
    N28 X28. Y0.1675
    N29 X29. Y0.169
    N30 X30.5 Y0.1735
    M5
    N31 Y-0.25
    N32 X0. F120
  8. #8
    Jan 2016
    Found my problem... missed a setting on the ESS config.
    All is well!
    Quote Originally Posted by Sileighty_Guru View Post
    M3 S800
    M1
    N2 X2. Y0.0108
    N3 X3. Y0.0190
    N4 X4. Y0.0263
    N5 X5. Y0.0360
    N6 X6. Y0.0453
    N7 X7. Y0.0543
    N8 X8. Y0.0655
    N9 X9. Y0.0773
    N10 X10. Y0.0860
    N11 X11. Y0.0973
    N12 X12. Y0.1065
    N13 X13. Y0.1140
    N14 X14. Y0.1200
    N15 X15. Y0.1263
    N16 X16. Y0.1303
    N17 X17. Y0.1340
    N18 X18. Y0.1390
    N19 X19. Y0.1425
    N20 X20. Y0.1490
    N21 X21. Y0.1540
    N22 X22. Y0.1580
    N23 X23. Y0.1590
    N24 X24. Y0.1620
    N25 X25. Y0.1645
    N26 X26. Y0.1660
    N27 X27. Y0.1670
    N28 X28. Y0.1675
    N29 X29. Y0.169
    N30 X30.5 Y0.1735
    M5
    N31 Y-0.25
    N32 X0. F120
