Need Help! Mach3 - BOB - Loosing steps
Page 1 of 2 12 LastLast
Results 1 to 12 of 22
Thread: Mach3 - BOB - Loosing steps
    Jan 2016
    Default Mach3 - BOB - Loosing steps
    I'm in the process of building my first machine with Mach and a Parallel port. I built one other machine running grbl. I have a issue with loosing steps on one of my dual x axis motors, so i wanted to take a look at the signal going to the drivers.
    Notice the missed pulses..and the noise.. I can tell that both axis are missing steps, but i dont really have a good way to compare that one has x more than the other. (i wonder if the arduino interrupts would be fast enough to sample the pulses)
    Im using the amazon special SainSmart BOB
    I also looked a bit closer and found that they were not in sync. Not out by too much about 1.5us but im not sure how close they should be either.
    So fellow CNC'er i ask you all for advice, what should i be looking at next, could it be a BOB issue, PC issue... Should i just bite the bullet and buy a smooth stepper board?
    Mods, i looked for a troubleshooting thread but came up empty handed, if this needs to be moved, please do so.
    Mar 2003
    Default Re: Mach3 - BOB - Loosing steps
    First thing to do is run drivertest.exe from the Mach3 folder. Disregard the "System Excellent" message if you see it. What you're looking for is a smooth, flat line, and a steady pulse rate.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Jan 2016
    Ok, Next steps today, i did run the driver test file, however it wasn't very intuitive what i should be seeing.
    I took the parallel cable loose from the PC and probed it directly, same missing steps. No noise however.
    Mar 2003
    Watch the pulses/second at the top, and see how steady it is.
    And the graph should be a single horizontal line, not like yours. While your isn't ideal, I'm not sure that it's the cause of your problems.
    What do you have your pulse widths set in motor tuning?
    Jan 2016
    I tried 0 an 5 us. ... Gave up.. ordered a ESS... Should solve my issues..
    Registered propellanttech's Avatar
    Sep 2011
    What operating system???
  7. #7
    Jan 2016
    Quote Originally Posted by propellanttech View Post
    XP sp3 x32
  8. #8
    Sep 2011
    Let me explain why I asked;
    Any Windows operating system after 98 doesn't give the parallel port priority with relation to time. Hence why many systems have moved away from the parallel port. The pulses can be interrupted by anything Windows deems more important, hence lost pulses. You do not have this problem is running Linux, or other operating systems.
    This may not be the problem, but be very careful to not let a screen saver or any other program run while using Mach 3. You should have no screen saver, and the power options should be set where everything stays on except possibly turning of the monitor feed, which lets the monitor power down to a sleep state.
    Your mileage may vary.
    James L
  9. #9
    Jan 2016
    Yeah, Windows isnt a RTOS, so im not surprised to have this issue, What i was surprised to see was that the data streams were not in sync. I would think the computer (its like a 2+ghz machine) could fire the interrupts to generate the pulses more accurately than 1.5us. I tried almost every setting i could find referenced to enable "high power, etc". It was so bad just jogging the machine around with the keyboard would cause my gantry to become unsquare. Hopefully this ESS will fix my issues, and now i can actually put a more modern PC on this machine.
  10. #10
    Dec 2004
    James L
    Disagree! Using the same computer (dual booting from separate SSDs in BIOS) and PP, Mach3 under Windows 7 outperforms LCNC under Debian Linux. And the latter is using a kernel with RT extensions geared towards LCNC use. I'm able to get the maximum PP step rate of 100KHz indefinitely with Mach3 but limited to 60KHz with LCNC. Granted, a certain amount of savvy is required in order to get Windows to perform this way, but the same applies to Linux.
  11. #11
    Sep 2011
    Quote Originally Posted by eldata View Post
    Disagree!. Using the same computer (dual booting from separate SSDs in BIOS) and PP, Mach3 under Windows 7 outperforms LCNC under Debian Linux. And the latter is using a kernel with RT extensions geared towards LCNC use. I'm able to get the maximum PP step rate of 100KHz indefinitely with Mach3 but limited to 60KHz with LCNC. Granted, a certain amount of savvy is required in order to get Windows to perform this way, but the same applies to Linux.
    I stand corrected.....I'll stick to ethernet connections.
    Thanks for the education,
    James L
  12. #12
    Mar 2003
    Mach3 performance is very much tied to the specific PC. Some PC's run mach3 very well, and some can't run Mach3 at all.
