Problem with Z AXIS pin 6 and 7 motor only runs one direction. Swapped drives problem stayed the same. Took the terminal block off A axis and Z axis Drives . Swapped them now z axis will move in both directions A now only one way. So the direction pin is not working. I am to assume my break out board is bad? Software is set z axis pin 6 and 7 A axis 8 & 9 .The software shows a change in direction, in the dro when pressing jog buttons .The system is a smooth stepper feeding a c-10 break out board. The motion is very smooth and quiet. It fixed my p-port problem or driver issue. I am also having a problem with limit switch input. But that’s for later
That is usually a sign of bad or no contact on a motor pin. Try another set of pins other than the two that you know are bad. It could be a bad solder on the BOB.
You most likely already have but while you're at it, take a meter and re-check all of your cables. Not just for good continuity with each wire, but for a shorts between any two wires or to ground. Wiggle the cable as you check each wire to check for possible intermittent issues also.
My machine is using 4 gecko 320x drivers .They have a terminal block that can be removed with all the wires connected. So I removed the block and switched the Z axis block with A now Z works so that rules out a wiring problem encoder problem , motor or driver problem . It leaves the connection between the smooth stepper and breakout board or a problem with the smooth stepper or a bad C-10 break out board .I'm leaning toward the C-10.
