problem in autozero tool
Results 1 to 14 of 14
Thread: problem in autozero tool
    Registered Lc1975's Avatar
    Jul 2014
    Default problem in autozero tool
    Hello.
    I use mach3 and also mach3 2010
    Never had any issue with autozero tool..
    But...
    I have this configuration
    AutoZero Settings:
    X -22.000
    Y +220.000
    Plate Thickness: +20.000
    Clearance Plane +30.000
    Material Offset +21.000
    Every time that i make a autozero in Z axis manually the coordinates are ok..
    The tool goes 30mm above the material...
    When i insert a .txt with the "Z0" on the top of the material...
    On the tool change the software marks the "Z0", not in the top of the material but on the base of the table..
    Goes to only 10mm above the material and not 30mm
    I press "FeedHold" button move manually to the autozero i do again another "Z0" and the coordinates stays ok...
    Always used this configuration and never had problem...
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: problem in autozero tool
    Turn off material offet.
    With Material Offset on, you are setting the top of your part to Z=21, so when it moves to Z30 it's only 9mm above the part.
    UCCNC 2017 Screenset
    Jul 2014
    If i do that turn off the material offset the "Z0" is on the table and when starts to cut, goes in to the table and not the top of the material...
    Goes to 30mm above the table and not 30mm above the material to cut...
    I want that when i send machine to "Z0" the tool stays on the top of the material... And then go to 30mm above...
    Manually does this...
    When uses M6 the machines assumes the "Z0" at the bottom of the table and not on the top of the material to be cut...
    Mar 2003
    Shelby Township
    Is your zero plate on the table, or on top of your part?
    Jul 2014
    The "Z0" is on the top of the part...
    I don't now if this this correct.. But i think:
    The part has 21mm thickness
    The fixed plate has 20mm thickness..
    Put this values on the Tool Change..
    Material Offset: +21.000
    Clearance Plane: +30.000
    Then the tool when makes M6 goes above the part 30mm
    Correct?
    Mar 2003
    Shelby Township
    You don't use the fixed plate thickness, you use the movable plate thickness.
    Where are you using your movable plate? On the table, or on the part?
  7. #7
    Jul 2014
    im using the fixed plate to make the "Z0"
    Since the tool change is in the same position i use that for the rest...
    Wrong?
  8. #8
    Mar 2003
    Shelby Township
    That's fine, if the fixed plate is on the table.
    Then the plate thickness is 20, and Material Offset is 21, and should work, if the Material Offset box is checked.
  9. #9
    Jul 2014
    Manually works ok..
    Only when makes M6 and do automatically the Z0 is when goes wrong on the height of Z0
    Marks the zero on the bottom of the table and not in top of the part...
    If the cut is ex:
    -10mm
    The tool cut the table..
  10. #10
    Mar 2003
    Shelby Township
    Are you running the initial auto zero before the M6?
    The Initial Auto Zero stores the fixed plate location, which is used during the M6.
  11. #11
    Jul 2014
    Yes.
    Before i start the program i always make the Inicial Auto Zero in the Fixed Plate..
    Then when appears M6 goes to the fixed plate change the tool, press Cycle Start, the machine does the "Z0" but when rize only go 9mm +/-
    above the part...
    I click on "feedhold", the i move the tool to fixed plate, i make again the "Z0" and then the tool goes 30mm above the top of the part...
  12. #12
    Mar 2003
    Shelby Township
    Are you using the parallel port, or a motion controller? If motion controller, which one?
    What version of Mach3?
    You said it used to work, then stopped working? Your Mach3 install or .xml may have become corrupted?
    I don't really have any other answer.
    If it worked before, then that should tell you that there's nothing wrong with the macros.
    Here's what the macros do.
    When you run the initial auto zero, it first sets Z zero, relative to your part.
    It then moves to the fixed plate, touches the plate, and save the plates position. In your case, the plate location that gets saved should be -1, as it should be 1mm lower than the top of your part, correct?
    Then, when the M6 macro runs, it should touch the plate, and the Z DRO should be set to -1. Watch it, and see what it gets set to?
  13. #13
    Jul 2014
    Im using paralell port and the last version of mach3
    Yes the touch plate is -1mm of the material.
    Manually set the machine and it's all ok...
    Only in the M6 move is when the Z gets wrong...
    im going to reinstall again mach3 and 2010
    Maybe some file be corrupted..
    Because in previous works or days.. i didn't have any issue with this...
    Now im finish a new assembly of the machine.. i will install again then i will say if is ok or not..
    Thanks for the help and your time.
    Regards.
  14. #14
    Mar 2003
    Shelby Township
    Try using 3.043.062, rather than the latest version.
