I have my own CNC machine home made and i'm using Mach3 software every thing is good except limit switch , when the machine hit limit switch it's stop very well . but i need the axis to back off 10mm from limit switch when it's touch limit switch .
Thank you
I have my own CNC machine home made and i'm using Mach3 software every thing is good except limit switch , when the machine hit limit switch it's stop very well . but i need the axis to back off 10mm from limit switch with it's touch limit switch .
