G-Code newbie here....
With 20000 steps per inch, velocity set to 300IPM and acceleration set to 20in's/sec/sec, is there a reason why these two routines should behave differently;
; Routine 1
G00 X0
M98 P1 L1
M30
O1
G00 X-9.00
G00 X0
M99
;Routine 2
G01 X0 F300
M98 P1 L1
M30
O1
G01 X-9.00
G01 X0
M99
Routine 2 behaves as if there is no deceleration at the end of the G01 X-9.00 move and hence the servo drive faults. No problem with the G00 routine 1. Shouldn't G01 moves be following the same movement profile as the G00 moves in this case?
This is a myopic concept of speed, velocity and acceleration. It would be similar to saying that Venus Williams cannot serve a tennis ball at 120MPH since it would never travel 120 miles in an hour.You really think your motor can move your machine 20 inches in 1 second
A velocity greater than 1200IPM would be required in order for my machine to move 20 inches in 1 second but that does not mean the motors cannot achieve an acceleration of 20in's/sec/sec. It just means that it will reach maximum velocity of 300IPM in around .3 seconds.
Nope! You're not making sense since there is no faulting using G00 moves instead of G01 moves. All indications are that linear interpolation is not using the same movement profile as G00 rapid movement. Perhaps the direction change has something to do with it.this is why you are getting a drive fault, this is set to high
Go figure...I'm supposed to be the loopy G-Code newbie tuning a servo setup.Why are you using sub programs for just moving to a position
It may be a Mach3 bug in it's trajectory planner?
UCCNC 2017 Screenset
Probably. Here's the best workaround I was able to come up with;
G01 X0 F300
M98 P1 L5
M30
O1
G01 X-9.00
G00 X-9.00 ;no physical move
G01 X0
G00 X0 ;no physical move
M99
The above now behaves exactly like G00 moves at whatever feed rate chosen in the first line.
I agree with the OP. Both code snippets should have the same speed profile since the max axis speed is 300 IPM and the programmed G1 speed is also 300 IPM. Since it only misses steps when using G1F300 then there is something not right in the planner. The acceleration/deceleration should be applied to either G1 or G0 moves the same. Another reason I don't use Mach3.
Incidentally 20 in/sec^2 is not an extreme acceleration. This value just represents the slope of the acceleration/deceleration portion of the motion profile. My machine uses the same 20 in/sec^2 acceleration value with a top speed tested to 250 IPM but set conservatively at 200 IPM. My machine runs just fine with those settings in LinuxCNC.
At 20 in/sec^2 and 300 IPM (5 in/sec) top speed, the machine should be able to accel from stop to full speed in 0.25 seconds and 0.0625 inches. So, the 1/16" at each end of the motion profile should be an accel or decel respectively.
Because Mach3 is sending improper steps.Correct the problem is that the servo he has can not decelerate, before it is out of position
I know what you are saying, from his first post he said it worked ok with G0, (max Rapid )
There are many using Mach3 at much faster speeds than that and don't have a problem, 1000IPM Plus rapids is not uncommon with Mach3, I have run it over 400IPM with G1 G2 G3 with no problems
Mactec54
And there are many that have similar problems at much lower speeds.There are many using Mach3 at much faster speeds than that and don't have a problem,
It's well known that Mach3 has serious bugs in it's trajectory planner. It's just that most people don't run into them.
If I make a YT video out of this, are there any "legal" issues in referencing this thread?
I dual boot Windows 7 (Mach3 installed) and Debian Linux (LinuxCNC installed) on the same machine from separate drives.
Here are Z axis configuration screen shots for both programs;
The only real difference between the two is the step rate (due to encoder 2X decoding in the case of LinuxCNC) but the maximum velocity is the same 300IPM in both cases. Since LinuxCNC does not support M98/M99 commands, the looping capability was removed and the following was executed;
G1 Z0 F300
G1 Z-9
G1 Z0
M30
LinuxCNC ran this without a hitch but, as expected, Mach3 caused the drive to fault at the same place as before. Conclusion...Mach3 has an issue with the G1 command under certain conditions.
Edit:
2X decoding was also tried with Mach3, for a 50KHz step rate at 300IPM , making it more of an "apples to apples" comparison. Drive still faulted at the same place even when using a 60KHz kernel speed. This eliminates high kernel speed or step rate being the culprit.
Then you solved your problem run LinuxCNC for your control, it's a good control
You can't compare the 2 because of the Step rates being so different
Do you have a payed for version of Mach 3 ( With License Installed ) if not this could explain why you having this problem, I use Mach3 with the UC100 and don't have these problems, 300IPM is not fast at all Here is a machine that is doing a test cut at 500IPM, this is using Mach3 it has a rapid of 2500IPM
Mactec54
Post #5 in this thread indicated that my problem was solved days ago.Then you solved your problem run LinuxCNC for your control, it's a good control
You even quoted the edit in my post that addressed this.You can't compare the 2 because of the Step rates being so different
Even so, Demo Mode would qualify as a certain condition under which the G1 command has an issue. OTOH, cutting circles, even at a gazillion IPM, would not.Do you have a payed for version of Mach 3 ( With License Installed ) if not this could explain why you having this problem, I use Mach3 with the UC100 and don't have these problems, 300IPM is not fast at all Here is a machine that is doing a test cut at 500IPM, this is using Mach3 it has a rapid of 2500IPM
You're so hell bent on detraction that your posts have become nonsensical.
It would be embarrassing if I showed you it using G1, 300IPM is nothing what this machine can do, Posting the video was to show you that Mach3 does not have a problem at 300IPM and way above that, there can be some problems at speed when doing 3D, but there are work arounds for that as well, but no problem with G0 G1 G2 G3 normal moves
Not having a licensed Mach3 Demo Mode could easily be the problem, a lot of functions in Mach3 do not work correctly in Demo Mode
Try it at much slower feed rates in Demo Mode and it will work as it should
Mactec54
This no or very sharp deccelerations is a known mach3 bug and it was one reason why I migrated to UCCNC software.Even so, Demo Mode would qualify as a certain condition under which the G1 command has an issue. OTOH, cutting circles, even at a gazillion IPM, would not.
I had a purchased Mach3 license key and the same happened what you described here, not only in demo mode.
With my plasma machine this was a serious problem as it shaked my machine badly.
What you said makes sense...If I reduced acceleration (and hence deceleration) from 20in's/sec/sec to 10in's/sec/sec the issue would go away with the same 300IPM feed rate. Feed rate was never the issue, it was deceleration all along. But I chose to keep that to myself until now. The fact that Mach3 G00 moves have no issues with 20in's/sec/sec, LinuxCNC G01 moves have no issues under the same conditions, and placing G00 "placebo" instructions immediately after Mach3 G01 move instructions have no issues, suggests there can be issues with the Mach3 G01 command when relatively high deceleration is involved. I was never going to spend $175.00 just to find out whether Licensed Mode had issues or not, so thank you for your contribution to this thread.
20 in/sec^2 is not what I would call "high acceleration" by any means. Also, since your last post reveals that you are using the demo version of Mach, the manufacturer documentation says the demo is limited to 25kHz. 25 kHz and 20,000 steps/in would only be 75 IPM. are you using external step generation or parallel port?
