My program stops mid-cut. No error, no limit switch triggered
Results 1 to 7 of 7
Thread: My program stops mid-cut. No error, no limit switch triggered
    Mar 2014
    Victoriaville, Canada
    Default My program stops mid-cut. No error, no limit switch triggered
    Hi all ! I need your help ! I can't figure out why mach3 stops in the middle of my program. No errors, no limit switches triggered. Licenced version !
    Thanks in advance !
    Attached Thumbnails Attached Thumbnails My program stops mid-cut. No error, no limit switch triggered-p_20170211_104605_vhdr_on-jpg
    Member awerby's Avatar
    Apr 2004
    Default Re: My program stops mid-cut. No error, no limit switch triggered
    Is the license file in the right place? It should be in the Mach3 folder, but not in a subfolder. It sounds like the program can't find it, or the file's corrupt.
    Mar 2014
    Yes the licence file is in the right place. I did retry the gcode and it stopped at line 473 this line. It is very weird ...
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    In the Title bar, is says "Licensed to " and your name?
    Is the entire toolpath displayed, or only up to where it stops?
    If you don't see the entire toolpath, it's a license issue.
    UCCNC 2017 Screenset
    Mar 2014
    Here is the last screen shot
    My program stops mid-cut. No error, no limit switch triggered-capture-png
    Mar 2014
    And, yes in the Title bar, is says "Licensed to " and my name.
  7. #7
    Jan 2017
    Sounds like I'm having same issue here. Mach3 just stops no error no switches triggered, nothing flashing, please help. Tried to change denounce, no result.
