Problem #1 is an issue with the auto zero macro.
Problem #2 is probably an issue with the M6 macros.
It may be that you are missing some settings in the screenset that the macros use??
So I installed a touchplate which recommends using the mach blue screen.
Pretty simple inputs, touch the wire to the plate; green light on the probe setting comes on like it should. The problem is when i hit the auto-z button; the router will go down a little slowly, then just drives itself into the material very quickly. The light is on so the circuit completes, but doesnt ever stop itself.
That's problem 1. Problem 2 is running my previous G-codes, which I believe is on a tool change command wants to drive the router way out off of its limits in the x/y direction. I have the tool change location set to 10/10/3.... so i'm not sure what is causing this.
None of this happened before the mach blue install, uninstalling it doesnt help the situation.
UCCNC 2017 Screenset
Hi czwalga,
I have tried many screens and the best by far in MY opinion is
Once set up it works as it should every time.
No affiliation blah blah blah
Cheers
