Any suggestions on where I should look to debug this? This is the last item left to finish on this project.
Thanks,
Kent
Hello - I've been pulling my hair out trying to get Mach3 control of my Chinese 2.2kw spindle with modbus through a Hitachi WJ200. Unlike many of the threads I've read on the subject, I've gotten past the point where my rs485 converter is talking to the Hitachi. I can open the serial port and read registers from the WJ200, I just can't get Mach3 to control the spindle. I believe I've got some dumb error on the Mach setup screens or the brain config. Attached are screenshots of all the applicable (I think) settings. If you see anything obviously wrong, please let me know.
Thanks,
Kent
Thanks,
Kent
Hitachi makes good drives. Their manuals are horrible though. It is very hard to understand & find info.
I have the same setup: WJ200, 2.2kw, using Mach3. Has anyone figured this out? What was the solution? Can somebody send me your brains file? The spindle isnt moving at all, and not sure where to start debugging
I have the sme problem with my Hitachi VFD. Give up the fight, sooo, now the on/off function is controlled by Mach3 and speed is controlled by potentiometer installed near the keyboard.
My 2¢
Sorry for not having updated this old thread, but the solution I found was to try a different eBay RS485 converter. At only about $5 each, I bought a couple more from different sellers and all the problems were solved. I then found after a couple months of non-use that the spindle stopped working again. I broke out the spare converter and I was back in business. Lesson learned - always keep a few spares on hand!
The problem for me was that I couldn't set the rpm's right. The pulley setting did not have any affect at all.
My 2¢
I do not have the RS485 interface in use so I really no knowledge of this area. But when looking at the screen shots provided the "Relay control - Clockwise M3" value is set to 3 and the "CCW M4" is also set to 3. Is this correct that the same signal is used for opposing directions?
No, it would send both CW and CCW signals to the drive at the same time.But when looking at the screen shots provided the "Relay control - Clockwise M3" value is set to 3 and the "CCW M4" is also set to 3. Is this correct that the same signal is used for opposing directions?
However, most router users only use CW, and have no hardware wired for CCW. In that case, the Output 3 in the CCW field doesn't do anything.
UCCNC 2017 Screenset
Hi
My Hitachi X200 vfd just went up in smoke, been working great for years, was using Mach3 to control the VFD thru modbus. Just changed out the Hitachi drive to the new WJ200 series. Now I can not get the setup to work. Does anyone have the settings to use in Mach3 for WJ200? Plus I also need the brain file, and the parameters for setting up the WJ200 Hitachi drive
