Mach3 parallel port outputs
Results 1 to 3 of 3
Thread: Mach3 parallel port outputs
    Registered Drools's Avatar
    Feb 2009
    Default Mach3 parallel port outputs
    A quick question, can Mach3 be configured to use pins 14,16 and 17 as outputs?
    My drivers have an enable line and I would like to have the enable controlled by Mach3. As it sits I have my enable line tied to +5 so the drive is enabled all the time. Standard setup for Stp/Dir, 2&3, 4&5, 6&7 but that only leaves pin 8 as an output.
    Parallel port wiki Parallel port - Wikipedia, the free encyclopedia says pins 14, 16, 17 can be used as input or output.
    Thanks for the help.
    Note, I could install a second PP but I would like to avoid that.
    Thank You.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I believe so, but can't check right now.
    Go to ports and pins, Input pins, and look at the available pins for input. All the pins NOT listed as inputs can be used as outputs.
    UCCNC 2017 Screenset
    Feb 2009
    I forgot to get back to this thread, yes I was able to use pins 14,16,17 as outputs.
    Thank You.
