Set your X and Y offsets to zero.
Hi, I'm having an issue where I have a small piece of material say 12"x12" and my part is 11.5"x11.5"
I Ref all home and zero in the bottom corner of the material, but mach has my table work area offset slightly so the start point is not at 0,0 (x,y) in reality it starts cutting at ~ 2,2 (x,y)
is there a way to change this? I cant find the setting, and I looked in sheetcam also.
here is pictures of what I am talking about. It is visible on the mach3 table display box - shows the table as a dashed grey line.
- SteelTailor Portable CNC cutting machine how to check START or FINISH Signal?
- New Product- Year of portable Tube Cutting Machine Welcomes SteelTailor TubeTailor Cutting Machine
- Problem- When we press “Start” button,Why SteelTailor CNC cutting machine does not move?
- Problem- When I start to cut, there is no arc from SteelTailor CNC cutting machine torch?
UCCNC 2017 Screenset
Thank you, I had to change values in Homing and Limit config.
I missed that before
