You don't need an .xml, you just manually setup the machine by entering the proper information.where would you get an XML file when you connect to your computer and load Mach 3?
Imo, manufacturers that supply .xml files are doing their customers a disservice.
By manually setting up Mach3, you learn much more about your machine, and you're much better able to fix issues that come up.
