Need Help! mdi issues
Results 1 to 7 of 7
Thread: mdi issues
    Jan 2017
    Default mdi issues
    So thus far I have been working with my machine that I built (actually the 3rd in a year) and have been learning lots. As of late I have been trying to take out the small amount of backlash on my machine so I manually do a gcode command in the mach3 mdi which has worked flawlessly until last night. The code is a simple g01x1 . Now all of a sudden when I input the code the machine will take off the wrong way and not stop even though I the command was only for one inch. Other times the softlimits will chyme at me even though I am no where near the limits. And sometimes it will actually move the way that I want it to. Has anyone else ever had this issue? Like I said it was not doing it before, it seemed to start when I put values into the backlash box. I don't even have it turned on at the moment.
    Brad
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: mdi issues
    Is it possible that you were in a wrong mode (G90/G91) when you typed the G01 command?
    Does the machine move as expected in other situations (jogging with the cursor keys or running a G-code file)?
    Jan 2017
    Quote Originally Posted by CitizenOfDreams View Post
    I am positive it was a go1 command, everything else seems to be working fine. If I jog it goes exactly where it is supposed to. I ran a gcode file that was generated by the wizard and that seemed to be fine as well. It was working just great until I put my backlash numbers in and turned it on. Then I started to get the problem. Not sure if it is even related. I turned off backlash and am still having the issue. When I input a g01 command it should just move from the position that I am in correct? Should I have to zero out the dro? From my understanding this should just move away from the current position and it was working fine.
    Thanks for your response
    Nov 2012
    Quote Originally Posted by Brad777 View Post
    If you are in G91 mode, then G01X1 will move the tool 1 unit to the right.
    If you are in G90 mode (after running some G-code or a script that had a G90 in it), then G01X1 will move the tool to the X=1 position.
    Look at the status line in the upper right corner that starts with "Mill ->...". Does it say G90 or G91?
    Jan 2017
    Ok I will check that out when I get into the shop tonight.
    Jan 2017
    That was spot on! Thank you so much for your help. I learned some more today.
  7. #7
    Nov 2012
    You are welcome, glad we found the problem.
mdi issues
mdi issues
