Problem cutter path deviations
Results 1 to 1 of 1
Thread: cutter path deviations
    Dec 2015
    Default cutter path deviations
    Hello all
    We seem to be developing a problem with out cnc router (precix 4x4 with ATC) At certain angles of cut I get a move off of the programmed cut by a 1/2 mm or so. it seems to mainly on the X axis, but not all of the time. I am cutting 2mm aluminum sheet, and on in internal profiling cut it takes 3 passes at .8mm to cut through the part. On the first pass it looks good but deviates on the 2nd and 3rd. See picture labeled A. you can see other areas where it went of path as well.
    I will see if I can take any backlash out of the x but I have measured it and it has not changed over the last year.
    James
    Attached Thumbnails Attached Thumbnails cutter path deviations-cutter-path-deviations-jpg
