Button for: goto Safe Z, then G0Y0 and G0X0
Results 1 to 4 of 4
Thread: Button for: goto Safe Z, then G0Y0 and G0X0
    Oct 2016
    Default Button for: goto Safe Z, then G0Y0 and G0X0
    I must make some production with 100 times the same acrylic sheet.
    I’m searching to make a button script what can do the following:
    - goto Safe Z
    - goto G0Y0 (with a slower jog speed)
    - goto G0X0 (with a slower jog speed)
    The goal is, if I click this button then the spindle must go always back to center of the new sheet and then I do a new Auto Tool Zero.
    I know the G0Y0 and the G0X0 command but not how to slow the jog speed. Now it goes to fast.
    Can someone help me?
    Thanks,
    Ritmeester
    Member Kenny Duval's Avatar
    Jan 2013
    United Stated
    Default Re: Button for: goto Safe Z, then G0Y0 and G0X0
    G0 is a full rate move so you would have to set the Mach 3 to limit the maximum IPM of your machine as that is the value used for the full rate movement. If you want a slower rate of movement back to the zero location you'd have to use a feed rate or G1 move to accomplish this. The problem you'll have is that the Safe Z movement will put the control in a G0 state so the you would have to issue something like G1 X0y0 F40 for example to put the control back in to a G1 state and the F40 would be the feed rate.
    Oct 2016
    Kenny,
    I will tomorrow experiment with this and let you know.
    Thanks.
    Oct 2016
    Thanks.
    I experiment with: (Metric)
    G1Y0 F600 and G1X0 F600
    This goes very well and I’m happy with this. I have also downloaded MachScreen 1.66 and will tomorrow make some buttons for this.
    Btw, I can’t find the commando for “goto safeZ” I have this button on the remote but I also want to have this in the script.
