It sounds like one of the axes of your machine is running in reverse. In Mach3 Config/ports and pins/motor outputs change the "Dir low active" bit for that axis and it should run in the other direction.
I have a drawing of an electric guitar body
drawn in solidworks then converted to Rhino Cam
when I simulate in Rhino everything is perfect
after I post the tool path and load the G code into mach3
and start the toolpath it cuts in reverse or mirror
please help
Michael E Boggeman
Midwest Guitar
314 962 8822
