Need Help! axis change
Results 1 to 2 of 2
Thread: axis change
    Apr 2011
    U.S.A
    Default axis change
    Have Mach 4 latest build Lathe , I need to change Z axis to X axis , because my Bobcad v 29 lathe does not write the gcode to the correct axis , for my machine . I have talked to Bobcad for a week , no results . Need help
    Member CS900's Avatar
    Aug 2006
    Default Re: axis change
    you should be able to configure your post processor in bobcad to switch the axis. I assume you're using the Z axis the rotational axis of the lathe, and X for the cross slide?
axis change
axis change
