Mach3 USB Motion Card STB4100
Results 1 to 5 of 5
Thread: Mach3 USB Motion Card STB4100
    Feb 2014
    Default Mach3 USB Motion Card STB4100
    Hi
    Does anyone have Mach3 USB Motion Card STB4100?
    I bought it on Aliexpress. It´s made by Hongbang Motor Co., Ltd. My question is which pin should I use for axis step and dir?
    The manual say 0 on all pins and ports for the axis.
    Pin 1, 2, 3 and 4 are used for input switches and works fine.
    Gaute
    Feb 2014
    Default Re: Mach3 USB Motion Card STB4100
    Are there any way I can test the card to find who are who of the pins?
    Sent from my iPad using Tapatalk
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    According to the manual I found, it looks like you leave them all set to 0.
    UCCNC 2017 Screenset
    Feb 2014
    Thank you ger21, Happy New Year!
    My problem is that I have set all parameters as per the manual but no life in the motors. I have contact with the board switches are working. When I enter a G code the Z motor give a short knock even if I wright G0 X100, G0 Z100 or G0 A100. The Mach3 is going to be used on my home bult slant bed CNC lathe. The A is for the auto tool change torret.
    Feb 2014
    ger21
    Happy New Year
    Yes you are right. It was silly me that did a termination mistake. It´s ok now.
