I don't have an example to share, however I have looked into this issue for NPT threads and there is capability to do that via a Mach3 wizard, using the taper setting. There is documentation on it as an attachment from Rich (moderator) on the forum discussion here:
You could also do it via a G32 threading move, just by inputting x & z coordinates to start and end at. Takes some math work if you are doing multiple passes, but works well enough. If you have a CAM generator, it should be able to be set to do threading in 'multiple passes' or something similar which would typically direct it to use the G32 command for output, calculating setover, proper X & Z coordinates vs. the G76 condensed code which will only do a straight thread.
Remember, you have to turn the taper as a separate operation before threading it.
