Mach 4 With 5-Phase Vexta Drivers/Motors
Results 1 to 6 of 6
Thread: Mach 4 With 5-Phase Vexta Drivers/Motors
    Jun 2005
    Default Mach 4 With 5-Phase Vexta Drivers/Motors
    Can Mach 4 work with Vexta stepper drivers which have a...
    Pulseforward pin
    and a...
    Pulsebackward pin
    --instead of a...
    Forward/Reverse pin
    and a...
    Step pin.
    Thanks.
    (I have a few Vexta Harmonic drives, you know, for extra axis : )
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: Mach 4 With 5-Phase Vexta Drivers/Motors
    Hi
    I'm not sure where I found this to convert step + direction to step CW & step CCW and vis versa -
    Mach 4 With 5-Phase Vexta Drivers/Motors-clock-converter-circuits-jpg
    either circuit is made from a quad 2 input NAND gate IC like the 7400 or later version like 74HC00
    Mach 4 With 5-Phase Vexta Drivers/Motors-7400-quad-nand-gate-jpg
    John
    Jun 2005
    Well, that was nice : )
    Thank you.
    It's not as simple as a software solution, but it will keep me from even having to think about discarding stepper motors with zero-backlash harmonic drives attached, especially this motor with a 370 Kg/Cm torque rated harmonic drive, which seems like it really wants to be part of a small homebuilt 5 axis machine, once I add a coupler/bearing assembly.
    Mach 4 With 5-Phase Vexta Drivers/Motors-img_0709-jpg
    Mar 2007
    uk
    Hi
    I think I found the circuits when I needed to convert the inputs to an electronic counter
    I've just had a quick web search for drivers that can use either step & direction or step CW & step CCW inputs
    so far I've only found 2 phase drives like this -
    STR Series : Step and Direction Stepper Drives
    http://www.omega.com/Manuals/manualp...TR2_Hdware.pdf
    from page 14
    Mach 4 With 5-Phase Vexta Drivers/Motors-page-14-jpg
    John
    PS
    initial thoughts for possible PCB layout for signal converter - use one IC per axis
    Mach 4 With 5-Phase Vexta Drivers/Motors-clock-converter-cw-ccw-jpg
    Jun 2005
    And thanks for your initial thoughts. : )
    I saved this webpage in Firefox's Scrapbook
    https://addons.mozilla.org/en-US/fir...don/scrapbook/
    Programming stuff like this is trivial on an Arduino, but I may not be using one for a controller to control the drivers that drive the motors.
    This is my first contact with TTL.
    Thanks, again.
    Mar 2007
    uk
    the earliest logic element I've used was
    a Mullard NORBIT 2NOR60 - twin 4 input NOR gate
    made with discrete components assembled on a potted PCB
    ttl devices are from 60's and there has been various versions over the years
    including TTl compatible CMOS devices including 74HCT series
    any one wanting to do things the hard way for the challenge
    you could build a clock using transistors to build
    all the logic elements without using ready made logic IC's
    Transistor Clock - Nuts & Volts Magazine - For The Electronics Hobbyist
    John
