Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: X3 Motor Problems
    Aug 2007
    UK
    X3 Motor Problems
    Hello all
    I need some urgent assistance, so any help would be much appreciated.
    We have just finished the conversion to CNC of my X3 mill using CNC Fusion kit with adapted Nema34 motors - the CNC side works very well indeed. The only problem is, I now have a problem with the actual mill motor.
    When used at slow speeds, it seems ok, although if you watch closely, when the cutter has to do any serious work, the speed jumps irratically. When turned up to anything above 50% speed, there is a distinct electrical burning smell, and sparks in the bottom of the motor.
    Does anyone know a direct replacement motor for the stock job - possibly slightly more powerfull but just straight swap, or the actual current of the standard motor so I can source a replacement locally.
    Any help would be much and greatly received.
    Cheers
    Westy
    Nov 2009
    you can find motor here
    http://www.kelinginc.net/NEMA34Motor.html
    b.r
    Aug 2007
    UK
    Hi
    Thanks for the quick reply, but its not the stepper motors that are the problem, its the actual drive motor for the mill.
    Cheers
    Westy
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Post
    Westy,
    Arc Euro Trade has the OEM motor in stock.
    http://www.arceurotrade.co.uk/Catalo...ll-Mill-Spares
    X3-224 X3 #224 Motor £89.95 In Stock
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Aug 2007
    UK
    Hi Jeff
    Yes, I have seen that, I think it is probably the best and quickest solution to the problem. I just thought that while I am in this prediacment, I could take it as an opertunity to upgrade the motor. The original one, although 2 years old has done hardly any work and is as clean as clean can be.
    Thanks for the post though. If anyone has any ideas on a reasonably priced upgrade without much work involved, please feel free to post.
    Cheers
    Westy
    Feb 2007
    U.S.A.
    Post
    Westy,
    I forgot to ask if you checked the brushes on the motor.
    A good cleaning and polishing the commutator may help a lot.
    See instructions below:
    The commutator should remain a polished surface.
    Blackening may indicate rough or eccentric commutator.
    Occasional wiping (power off) with dry canvas or non linting
    cloth may suffice. If rough or excessively dirty,
    smooth with very fine (00) sandpaper lightly with
    armature rotating. Never use emery cloth. Never allow the
    brushes to wear so short that spring tension is lost. The
    resultant sparking will damage the commutator.
    If frequent dressing is required, the cause should be
    found and corrected. A very rough commutator should be
    turned in a lathe, at high speed, with a sharp tool. Do not
    remove more copper than necessary. The mica should be
    undercut if necessary.
    On a separate note, you may start looking for treadmills that people discard.
    On garbage day you may find them in the trash for free.
    Most of them have 1-2 horsepower D.C. motors and a controller too.
    Lots of Zone members have retrofit them onto there mill.
    Jeff...
    Registered Crevice Reamer's Avatar
    Mar 2008
    Hi Westy.
    Jeff has given you good advice:
    http://www.reliance.com/prodserv/motgen/h7000ch1.htm
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Aug 2007
    UK
    Thanks guys - most helpfull.
    I have stripped the motor down and found the copper to be very dirty in areas.
    Placed it in the lathe and used the non abrasive side of some abrasive cloth to clean it of to polished finish.
    The contact surfaces of the brushes were a mess, so I have lightly cleaned them with fine sand paper.
    On first assembly, the motor failed to work - so I am going back out this morning to have another go - but I am sure you hit the nail on the head.
    Cheers
    Westy
    Mar 2008
    After you replace the brushes, you must wear them in to their correct, commutator-fitting shape. You do this by mechanically (No power to motor) turning the motor (with an outside power source like a drill, or motor shaft chucked into lathe) until they wear in.
    You can start this process by wrapping sandpaper around commutator and sanding brushes (sideways) to rough shape.
    Make sure the brushes go all the way down into the sockets and actually CONTACT the commutator.
    CR.
    Aug 2007
    UK
    Hi Guys
    Thanks for all the help and suggestions. I removed the brushes, cleaned up the copper and refitted the brushes having bedded the in without power first.
    The motor works 95% good - I have ordered a new set of brushes and a new drive belt as this wasworn out too.
    Cheers
    Westy
    Mar 2008
    Good job Westy! Well Done!
    CR.
    Feb 2007
    Exclamation An idea!
    Now might be a good time to start searching for neglected low hour treadmill that could serve as a donor for a motor transplant. Getting the complete treadmill allows you to utilize the matching speed control unit.
    Usually treadmill motors will put out more usable power but will also put out more heat and will require a fan be fitted. Also they tend to be more open framed so protective covers might be needed to keep chips out.
    YMMV
  • Page 1 of 2 12 LastLast
    1. Problems with motor stalling due to motor/lead screw alignment
      By Bimmerkc1 in forum DIY CNC Router Table Machines
      Last Post: 01-24-2010, 07:12 PM
    2. Z motor problems?
      By skaha in forum Machines running Mach Software
      Last Post: 01-16-2008, 07:14 PM
    3. Motor/Controller PROBLEMS
      By wdenny in forum Stepper Motors and Drives
      Last Post: 05-04-2007, 07:58 PM
    4. Motor problems
      By johnm99 in forum Stepper Motors and Drives
      Last Post: 03-03-2006, 03:11 PM
    5. Motor Problems
      By MikeAber in forum Industrial Hobbies (Support forum)
      Last Post: 12-13-2005, 12:22 PM
