| LittleMachineShop CNC Machines Discuss LittleMachineShop CNC Machines here! |
Could you provide an X2 conversion kit with a larger work envelope? Something like the CNC Bridges, the Hoss2006 modified X2 or the one described in "Benchtop Monster is Born - Harbor freight 44991 / 33686 Hybrid CNC Conversion!!!". |
| Here is a link to the thread he is talking about; Benchtop Monster is Born - Harbor freight 44991 / 33686 Hybrid CNC Conversion!!! |
Sorry for the delay in getting back to you. Just getting up to speed here. We will have a larger X2 table in a couple months. It's something like 20% larger in each direction. Not as large as you are looking for, I don't think.
__________________ Chris Wood LittleMachineShop.com |
| We expect the larger X2 tables in about a month. They will be about $300. Here are some specs: The table is 120 mm (4.73") by 460 mm (18.11"). It has three 12 mm T-slots. The X-axis travel is 300 mm (00") and the Y-axis travel is 130 mm (00"). The dials are graduated in 0.001" and one turn of the hand wheels moves the table 0.050". The X-Y table is made of cast iron and steel. There are adjustable gibs on both axes.
| Chris, Does the upcoming larger X2 table connect to the Z axis in the same way as the stock X2 table? Does your CNC X and Y-Axis Motor Mounts and Screws for Mini Mill (Part Number: 3198) use acme screws or ball screws? Thanks again! |
| The larger X-Y table for the X2 connects just like the standard table. To switch you remove three bolts, move the column and replace the bolts in the new X-Y Table. Our CNC X and Y-Axis Motor Mounts and Screws for Mini Mill have Acme screws and anti-backlash nuts. Pretty clear in the photo: http://www.littlemachineshop.com/3198 Regards, Chris Wood LittleMachineShop.com
| Chris, Is the upcoming larger X2 table essentially the same as the one on Warco's popular mini mill and drill? Warco's popular mini mill and drill is described here: http://www.warco.co.uk/Mini-Mill-Drill-EBFC17B0BF.aspx . Thanks yet again! |
#12
| We expect the first batch of larger X-Y tables for the mini mill in the next two weeks. They will cost $299.95. We will get a photo and more information on our Web site as soon as we can after they arrive.
| HF 8x12(...14) 4 Jaw Suggestion | DeusExMachina | Mini Lathe | 12 | 05-23-2009 08:50 AM |
| Hoss X2 cnc conversion suggestion | meincer | Benchtop Machines | 1 | 09-21-2008 12:55 PM |
| A suggestion | shreifali | General Metalwork Discussion | 0 | 02-05-2007 09:44 PM |
| A suggestion and a thank you.. | murphy625 | Suggestions for the CNCzone.com site. | 1 | 03-05-2005 08:02 PM |
| New guy and I need suggestion. | dmgdesigns | DIY-CNC Router Table Machines | 7 | 01-31-2004 06:29 PM |
