Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > LittleMachineShop CNC Machines
LittleMachineShop CNC Machines Discuss LittleMachineShop CNC Machines here!
  #13   Ban this user!
Old 11-13-2009, 08:30 PM
ellik is on a distinguished road
Chris.
I just noticed you have the new larger table assembly for the X2 at LittleMachineShop.com. Since I have converted my X2 to a CNC it would be very interesting to get some more details of the internals so I can determine how I can utilize the larger base for my mill. How different is it from the original assembly? Is there more room for mounting ball screws etc or is it more or less the same, except for the extended travel of course?
EK
  #14   Ban this user!
Old 11-16-2009, 11:31 AM
Chris Wood is on a distinguished road
There is some more room under the table, but not a lot. The saddle is now 2" tall, maybe 3/16" taller than the regular X2 table.
Chris Wood
  #15   Ban this user!
Old 11-16-2009, 12:00 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Originally Posted by kanton View Post
Could you provide an X2 conversion kit with a larger work envelope? Something like the CNC Bridges, the Hoss2006 modified X2 or the one described in "Benchtop Monster is Born - Harbor freight 44991 / 33686 Hybrid CNC Conversion!!!".
The new table would be an easy bolt-on upgrade, but does not significantly boost table size or travel. Also, If you intend to CNC your X2, you really don't need all of the cranks etc. All you really need is the base/saddle/table plus gibs.
If you are competent, a far more practical CNC upgrade would be to purchase just those X3 parts from Grizzly
$141,25 X3 Base
$048,75 X3 Saddle
$005.25 X3 Y gib
$058.25 X3 Table
$004.00 X3 Table gib.
$016.00 X3 Gib adjusting screws/nuts
273.50 plus shipping.
http://www.grizzly.com/products/g0463/parts
You will have to fabricate ball screws, end plates/motor mounts/bearings and adapt X2 column to X3 Base, ala asammons, but that shouldn't be very difficult and will result in a large table size/travel increase.
CR.
HF 8x12(...14) 4 Jaw Suggestion DeusExMachina Mini Lathe 12 05-23-2009 07:50 AM
Hoss X2 cnc conversion suggestion meincer Benchtop Machines 1 09-21-2008 11:55 AM
A suggestion shreifali General Metalwork Discussion 0 02-05-2007 08:44 PM
A suggestion and a thank you.. murphy625 Suggestions for the CNCzone.com site. 1 03-05-2005 07:02 PM
New guy and I need suggestion. dmgdesigns DIY-CNC Router Table Machines 7 01-31-2004 05:29 PM
