Results 1 to 2 of 2
Thread: Help with Sieg CNC Mill Spindle / Collet
    Feb 2011
    I need basic help with setting up the collet adapter in the spindle.
    I see that the collet it threaded. I threaded it into the spindle. It goes in about 1/2" of threads. When I get to the top, it free-wheels. I have read about drawbar systems, but this unit clearly doesn't have a drawbar. T here is a knob at the top that is part of the spindle system. Turning it doesn't seem to have an effect.
    I have looked at the exploded parts diagram - it seems that I am to do something with the knob at the top, but I haven't found the magic yet.
    I am surprised that there is nothing in the kit that explains this basic function. Can you point me in the right direction. Obviously I have never use any mill before.
    Thanks.
    Feb 2011
    Solved
    I found a great pictorial of the setup. Makes sense.
    Sieg KX1 Installing & Removing the Cutter - iannewplayground
    Now out to the shop to test.
  1. High Speed Spindle for SIEG X2 Mill - getting technical
    By whelen in forum Benchtop Machines
    Last Post: 06-04-2013, 05:08 AM
  2. SIEG-SX3 Spindle play Need help!
    By civilseal in forum X3/SX3/G0619/G0463
    Last Post: 04-02-2011, 10:42 AM
  3. Sieg KX3 Spindle Gear
    By NickHaman in forum X3/SX3/G0619/G0463
    Last Post: 03-16-2011, 08:43 PM
  4. Sieg X1 Spindle
    By itsme in forum Benchtop Machines
    Last Post: 01-23-2007, 07:05 PM
  5. High Speed Spindle for SIEG X2 Mill
    Last Post: 07-27-2005, 04:58 PM
