Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > LittleMachineShop CNC Machines
LittleMachineShop CNC Machines Discuss LittleMachineShop CNC Machines here!
Old 04-06-2011, 12:51 PM
zarthcode's Avatar
zarthcode is on a distinguished road
Advice on spindle control for a LMS HiTorque 3900
I recently purchased the LMS SX2 (aka HiTorque 3900), and a cnc fusion kit. The conversion is nearly complete, with only a small amount of wiring remaining to be done.
I've got 4 relays available, and plenty of IO to do just about anything (My controller is a Mesa 7i43 with 7i47S and 7i42 daughterboards, great stuff). I'm using steppers instead of servos,
I've already added the ability to control forward/reverse, but how did everyone approach controlling the spindle?
The 7i47S has a VFD/Analog controller that can replace a potentiometer - which is simple enough. Is there a preferred way to maintain manual control as well?
Controlling the spindle on/off is something I'd prefer to do by keeping the built-in switch in the E-Stop loop. Does everyone simply turn it "on" manually and then use the relay to control the mains power? Looking at the built-in switch I was hoping I could wire a relay in series with the power switch, or maybe replace the built-in power switch with an e-stop. Ideas?
New Machine Build- LMS HiTorque Mini-Mill CNC Conversion djbird3 Benchtop Machines 241 04-16-2012 03:44 PM
Need Help!- FANUC A20B-3900 cards, etc. gbowne1 Fanuc 1 03-27-2011 08:53 PM
Just got my HiTorque Mini Mill macpod Benchtop Machines 4 03-14-2011 10:46 PM
LMS HiTorque Mini Mill moodyj2000 Benchtop Machines 3 01-18-2011 08:19 PM
Electronics advice needed for G540 spindle control. TXFred Benchtop Machines 11 10-20-2009 08:20 AM
