LittleMachineShop CNC Machines
Page 1 of 3 123 LastLast
Threads 1 to 20 of 57
Forum: LittleMachineShop CNC Machines
Discuss LittleMachineShop CNC Machines here!
  1. Need Help!- Lms spindle control 4213 G540
    Started by Joeb318‎, 11-22-2017 08:49 AM
    cnc, control, lms, mach3, spindle
    11-22-2017, 08:49 AM Go to last post
  2. Need Help!- KX1 Z retract issues
    Started by DangerousR6‎, 05-09-2017 11:58 PM
    issues, kx1, program, retract, running
    05-09-2017, 11:58 PM Go to last post
  3. KX1 CNC stuff
    Started by Steamboat Ed‎, 06-21-2015 08:24 PM
    coolant, improvements, kx1, photos, vises
    11-21-2016, 06:11 AM Go to last post
  4. KX1 Spindle Motor Speed Problems
    Started by Steamboat Ed‎, 11-20-2015 03:27 PM
    bought, diagnosis, kx1, motor, spindle motor
    11-20-2015, 03:27 PM Go to last post
  5. Help with LMS Spindle speed control
    Started by jstefano‎, 03-27-2012 11:06 PM
    161, 213, control upgrade
    10-04-2013, 10:33 PM Go to last post
  6. Questions from a new guy about LMS 3501 Seig KX1
    Started by totalmechanic‎, 01-10-2012 10:45 PM
    05-03-2013, 12:40 PM Go to last post
  7. Moved: LMS lathes compare sizes ability & dial in tolerance.
    Started by KennyV‎, 03-13-2013 09:26 AM
  8. New KX1 scale jog issues plus pics
    Started by Mark Stehr‎, 06-10-2011 11:35 PM
    03-01-2013, 09:57 AM Go to last post
  9. Moved: Hitachi Seiki CNC lathe replacement parts
    Started by Limabeans913‎, 02-05-2013 09:27 AM
  10. Moved: Connecting 2 Gecko G540 to Mach 3 for ATC
    Started by tgab101‎, 01-02-2013 05:36 AM
  11. Moved: I Have No Idea What I'm Doing Mill CNC Conversion
    Started by Nissan20det‎, 10-30-2012 06:47 AM
  12. Moved: Good Setup Budget?
    Started by SMK_Fabrication‎, 10-18-2012 11:54 PM
  13. Moved: new to cnc
    Started by jonesy604‎, 10-05-2012 05:49 PM
  14. Moved: Frenic 5000m Motor drive failure
    Started by danash138‎, 09-14-2012 05:24 PM
  15. Seminar: "CNC in the Model Engineer's Shop
    Started by Chris Wood‎, 12-19-2011 07:45 PM
    four, not, then
    07-18-2012, 10:01 AM Go to last post
  16. Moved: Possible bad stepper motor
    Started by brento‎, 06-01-2012 09:50 PM
  17. Moved: Grizzly g619 thoughts?
    Started by underthetire‎, 02-23-2012 12:05 AM
  18. Moved: fanuc 6m tool length offset
    Started by vulcantool‎, 02-11-2012 02:52 AM
  19. Moved: Need a micro heavy duty engraver
    Started by dbren‎, 02-04-2012 04:20 PM
  20. Question Spindle WOBBLE?
    Started by sheepdog‎, 01-24-2012 11:29 PM
    cause, look, maybe, not, placed
    01-25-2012, 02:30 PM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 2 users browsing this forum. (0 members & 2 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
