Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 02-03-2010, 09:46 AM
greybeard's Avatar
greybeard is on a distinguished road
No progress after using Stepconfig.
XYZ axis all tested OK in stepconfig using the "Test this axis" windows.
So I loaded the saved file (axis.ngc) in AXIS, via the desktop shortcut, and when I turned off the ESTOP, and the power on, I expected to hear the motors activate and hold, but didn't.
If I pressed any of the limit switches, a message indicated that the limit had been reached, so I assumed they were all OK, and I closed the messages.
I then tried to use the "Manual" tag to jog each axis, but while the + and - buttons produced a change in the location on the display , they had no effect on the motors.
I did the same using the keyboard controls, but with the same results.
The X and Y axis displayed motion corresponding to the chosen step size, or continuous,
but the Z axis would only show a movement of .002 mm if I used the continuous setting, and nothing in the fixed step settings..
If stepped all axis away from zero position, and then touched the "Home all" button, nothing happened to the axis readings, but I got the message "end of move in home state 5".
When I loaded one of the files in the examples folder, 3dtest.ngc, I got the same results.
Grateful for help in moving forward, as I assume I'm overlooking something basic.
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
Old 02-03-2010, 04:17 PM
vlmarshall's Avatar
vlmarshall is on a distinguished road
The message "limit reached" makes me think your travel directions might be set up wrong in the .ini file. Just a thought...
http://www.youtube.com/user/vlmarshall
Old 02-03-2010, 04:34 PM
marzetti is on a distinguished road
John-
I believe vlmarshall may be correct. This would be caused by stepconf reversing the sign as I described a few days ago. Just go into the .ini file for your configuration and check. I believe it was the step_velocity and perhaps the offset values that were wrong on mine. Good luck!
Old 02-03-2010, 04:36 PM
greybeard's Avatar
Perhaps my post didn't make it too clear.
When I hit the limit switch, the programme gave a response that I would have expected, ie it thought the motor had just hit the L/S on the correct axis, so flagged it up.
John
Old 02-03-2010, 07:37 PM
chester88 is on a distinguished road
Post your stepconf file. (find it under emc2/configs it ends in .stepconf)
your ini and hal file would be good too.
Chris M
Old 02-04-2010, 04:20 PM
greybeard's Avatar
Hi Chris.
I've managed at last to get the files from the ubuntu/emc machine into this laptop and hopefully attached as a zip file.
Is that OK, as I can't think how else to post them
John
Old 02-04-2010, 04:23 PM
greybeard's Avatar
marzetti and vlmarshall, thanks for your input. I'll have a proper look tomorrow, as it's taken me so long to get the files out and posted, it's time for me to get my head down again
John
Old 02-04-2010, 07:22 PM
Originally Posted by greybeard View Post
Hi Chris.
John
Yep that was good.
Right off the bat I see that the Z axis is set to only .002 mm long.
Thats why it only moved that long and why it doesn't find the homw switches.
I'll look deeper later.
Chris M
Old 02-04-2010, 07:35 PM
It seems that stepconf doesn't like the fact you put the negative travel on the right ( eg table travel 10 to -65)
Change it to -10 to 65 and try again. Let us know if that fixes it.
What was your reason to enter the other way ( I assume there was one)?
Thanks for finding this bug!
Chris M
Old 02-05-2010, 10:39 AM
greybeard's Avatar
Chris, it worked.
I changed to -10 and 65 as suggested, and the first thing was that now the Z axis responds exactly as the other two.
My setting was purely a hangover from the way I'd set up the machine for my previous software, best forgotten !
The "home all" sequence started, and manually pressing the limit switches produced the direction change and set the home position for each axis in turn as expected.
Regarding the lack of motor response during this "rehearsal", the penny dropped that my file was based on the example that AXIS opens with, albeit with my config settings. I had ignored line1 that says "AXIS splash G-code. Not meant to be milled".
I assume from this that I need to load a small test piece of G-code of my own before the motors will turn.
Or do I still have a problem ?
John
  #11   Ban this user!
Old 02-05-2010, 11:54 AM
John-
Glad you're making progress! You can indeed mill the "EMC2 Axis" gcode, I've done it several times. Just touch off and go. Works best with a v cutter. But you should see motor movement. Do your jog buttons work?
Greg
  #12   Ban this user!
Old 02-05-2010, 12:35 PM
greybeard's Avatar
Hi Greg,
The jog buttons all work in the test axis mode when creating the stepconfig, but as soon as I launch the Axis window, there is no activity from the motors at all.
When I hit the estop off, followed by the power on, I expect to hear the motors receive a holding voltage, and a slight "click" like they did during the test. But zilch.
The display shows the effects of the controls, both jog and homing, but deathly hush from the motors.
John
My first CNC... in progress! hi-tech CNC Wood Router Project Log 12 06-02-2009 04:45 PM
Design In Progress JoeDawg General Metal Working Machines 1 10-07-2008 01:48 PM
My work in progress... mrmz DIY-CNC Router Table Machines 0 08-21-2007 04:24 PM
progress! (pix) anthony CNC Plasma and Waterjet Machines 12 06-03-2005 04:56 PM
Router Progress samualt DIY-CNC Router Table Machines 8 12-06-2003 12:17 AM
