| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
When using the "Test this axis" window, and the "Run" command, does operating the limit switch stop the motor running ? In other words can I use this to find the correct settings for the limit switch for each axis ? At the moment, it has no effect, and I don't know if it's because the setting in the parallel port window is incorrect, or if I have another problem elsewhere. John
__________________ It's like doing jigsaw puzzles in the dark. Enjoy today's problems, for tomorrow's may be worse. |
| I've set up just the X axis motor connected to the controller, and gone through every possible setting for pin 11, my X limit input, both normal and inverted. When I use the "Run" command in the "Test this Axis" window, none of the settings produced any change when the N/C limit switch was pressed. The motor continued to run.
| Now added the Y and Z motors, with a N/C limit switch each, to the controller. No change is apparent in that the controller ignores the X and Z limit switches, but requires the Y limit to be open for that one to operate.
| All is solved. ![]() The contoller needs an inverted enable signal on pin one for the Y axis to behave like the other two axis. "Test the axis " I'm informed, doesn't react to the limit switches, so I'll have to go back to a real set up to locate and test them.
| "Test this axis" - unexpected result | greybeard | LinuxCNC (formerly EMC2) | 13 | 01-31-2010 12:21 PM |
| My "Crazy" high speed spindle test | SScnc | Benchtop Machines | 4 | 04-21-2009 07:16 AM |
| Need Help!- Interesting "Gross Position ERROR A" with no limit detection | A.A | Bridgeport and Hardinge Mills | 1 | 01-14-2009 02:45 PM |
| TM-1...Need to disable "safety switch" | jwknow | Haas Mills | 1 | 01-15-2008 10:52 PM |
| Anyone wish they had a switch for coolant options on the CNC88 "Auto-Off-On" | LarryNH | Fadal | 0 | 08-04-2007 06:11 PM |
