Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 01-22-2010, 05:34 PM
cnc-it's Avatar
cnc-it is on a distinguished road
Emc and servos
Hi I'm just starting to learn about EMC and was wondering what feedback is needed from servo motors.
Am I correct that if I have encoders but no tachos then I will need a frequency to velocity converter to give EMC both position and speed feedback.
I have Fanuc dc yellow cap motors and Fanuc analogue drives.
By the way how well does G41 G42 cutter comp work in EMC...is it reliable..?
John.
Old 01-23-2010, 10:18 PM
jmelson is on a distinguished road
No, you do not need tachometers for EMC. If you use an analog velocity servo amp such as a Copley, AMC, Servo Dynamics, etc. that requires velocity feedback, then it will need a tachometer.
OK, so the Fanuc control generates the velocity signal from the encoder pulses. There are boxes to do this, but they get fairly expensive. The Fanuc amps can be set for torque mode, but that requires some rewiring and a total retuning.
John.
G41/42 work quite well, but they do require strictly avoiding gouging the work side.
Some controls are quite forgiving on that. The techniques to avoid the gouges are pretty simple when setting up lead-in and lead-out points.
Jon
Old 01-24-2010, 05:09 AM
atex57 is on a distinguished road
Lead-in and inside corner radius approaches have changed considerably lately. I am running 2.3.4 on my Wells-Index and can command it to do a inside square pocket without using inside radii. The tool simply drives to the tangent point of the next wall and makes a corner leaving the radius of the cutter. Makes it much simpler on inside pockets. You do still have to use a lead-in but it can actually be from the opposite direction from the previous conventions. The lead-in must be long enough that the radius of the cutter can clear the next line. Ed.
Old 01-29-2010, 06:25 PM
cnc-it's Avatar
Thanks for the replies guys, just what I was after.
I didn't know my drives could be set for torque mode..will have to look into this one!
John.
Old 02-01-2010, 04:29 PM
kudos is on a distinguished road
with fanuc yellow caps and drives should't it be more of a case supply a +/-10v analog from EMC to drives, while reading encoder from motor for position and PID loop
do your motors have a tacho? most do which the drive will use for speed feedback, this normal goes straight into the drive so servo is in Velocity mode.
EMC can then close the loop for you again from the PID in EMC
ud need something like mesa cards to give you the analog out.
rob
Old 02-02-2010, 06:05 AM
elrado is on a distinguished road
Encoder - to -tacho
Hi
I could offer two chanel encoder-to-tacho signal converter, which distributes the encoder signals to the CNC at a reasonable price - 100 EUR.
Also I could offer FANUC caompatible servoamplifiers for all FANUC yellow cap motors. Analog DC4QR (supports current mode) and digital DC4QR-D (suppoorts STEP/DIR interface)
For more information www.semis.hit.bg
Best regards
Radoslav Tchipanov
Old 02-02-2010, 11:40 AM
rob
The Fanuc Yellow Cap motors generally do NOT have a tachometer. That function was performed by the CNC control, converting encoder counts to an analog velocity signal to close the velocity loop at the servo amp. When you pull the old control out, you lose that function.
Yes, in theory, you could use the analog output of the Mesa to do this, but it needs to have pretty good resolution. The Pico Systems PPMC has a 16-bit DAC, so you get 8192 discrete values in both positive and negative polarities. I think the Mesa only has a 12-bit DAC, so you only get 2048 values in each polarity. I don't know if this granularity would affect the stability of the servo
amp.
Jon
Old 02-03-2010, 02:05 PM
Jon
I see what you mean never really noticed this before looking into it, had a look in tech manuals and at one of the machines today
i see you can use a tacho tho with drives no problem if u had one or could pick one up
just need a 7.5V/1000RPM & drive jumper change etc
then ether move the encoder to the screw or make a spacer or something up for both to live on the motor end.
to buy a tacho might cost as much as a converter board though i guess?
rob
Old 02-03-2010, 11:29 PM
Two channel encoder -to tacho converter (i.e. for two axis) costs 100 EUR
Radoslav
Old 02-13-2010, 06:23 PM
cnc-it's Avatar
Thanks elrado I have your site on my favorites now. Looks to be just what is needed. A tach signal could be fed to the drive and the encoder signal to EMC...?
John.
EMC and servos RP Designs LinuxCNC (formerly EMC2) 4 05-07-2009 11:06 PM
Newbie- Which servos? jessslp05 Servo Motors and Drives 5 05-05-2008 12:56 PM
Can't get servos to run.... REVCAM_Bob Servo Motors and Drives 1 05-26-2007 09:52 AM
Servos ? deleteallusers Servo Motors and Drives 1 02-16-2007 05:09 PM
What RPM for servos? jpsexton DIY-CNC Router Table Machines 1 08-13-2003 11:27 PM
