| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
At first I thought the screw couplers were loose but that wasn't it. The machine is a mini-mill with a g540. Reliable up until today. The code being run was CAM generated. Large files with many small moves. The commanded movements were mm to 4 decimal places, well beyond the capabilities or resolution of this machine. My normal programs are dimensioned in inches to 3 decimal places. So the question: Could the precision used in the gcode be the cause of the loss of position ? As an accumulative effect of very small moves and a very large file? One axis was out close to 3/16".
__________________ Anyone who says "It only goes together one way" has no imagination. |
| Arghh....another theory shot down in flames. There were a whole lot of things plugged into that outlet. In addition I was using a a jigsaw, probably on the same line(?). Could it be a case of to much power demand ? I'll check the setup. Using stepconf is good entertainment. Tommorow....it's getting late here.
Steppers running on a gecko g540. A little background: It's a Sieg mini-mill fitted with 5 tpi ballscrews. I've owned it for a few years and I'm very familiar with it mechanically. It used to have Xylotex drives and has done a fair amount of 3d profiling with those drives. No problem. A while back it was switched over to the gecko. Since then it.s only been used for drilling holes, cutting a few pockets, simple stuff and short programs. The step and direction timings are the ones provided by emc for these drives. The computer is the same one I've used for several years. All the electronics have ample cooling. Right now the machine is running a loop, dropping to z -1 in in 0.100" increments and then returning to z 0 in the same increments. The loop is set to 1000 cycles. Nothing unexpected is happening. Next I'll try the same loop in 0.001" increments. This is frustrating.
| I was losing steps too. My problem was cpu load on my computer. Next time you run a file, launch htop first. That will help you rule out that as a problem. Don't run the gui "system monitor". The graph consumes huge cpu. I changed video drivers and stopped using the backplot screen (I run the DRO instead) |
| Anyway..... The problem may be solved The G540 settings in the stepconf drop down box are not sane. The tool was 0.150" out of position on the z at the end of a 3d program used to test. Using a G540 stepconf file found on the emc wiki gave better results. 0.060" out of position on the z. Adding another 1000 to the step timings brought that error down to 0.005". That's the approx backlash on the z, so it might be dead-on for steps. The settings may still be a bit off optimal but I'm calling this one solved.
I didn't ask for help from Gecko if that's what you mean. I respect their products. Wouldn't have bought one otherwise..
| Losing z position during 3D profiling | functionbikes | Tormach PCNC | 4 | 08-18-2008 06:40 AM |
| T32 Losing position | apylus444 | Mazak, Mitsubishi, Mazatrol | 2 | 07-26-2008 10:57 PM |
| Tormach losing Z position | geomagnet | Tormach PCNC | 11 | 05-21-2007 07:05 AM |
| losing position in X | martsto | Milltronics | 3 | 03-15-2007 08:55 PM |
