Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 01-10-2010, 05:03 AM
faran is on a distinguished road
Please help: Running EMC2
Hi every body
I have Ubuntu 8.4 and install emc2 form live CD successfully. now i want to install emc2 from source code but i have some problems.
I can configure and build emc2 successfully, but when i run emc2, i see these errors in terminal:
Machine configuration directory is '/home/faran/emc2/configs/stepper'
Machine configuration file is 'stepper_mm.ini'
Starting EMC2...
module_helper is not setuid root
Realtime system did not load
Shutting down and cleaning up EMC2...
RTAPI: ERROR: could not open shared memory (errno=13)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -9
NOTE: 'rtapi' kernel module must be loaded
Cleanup done
EMC terminated with an error. You can find more information in the log:
/home/faran/emc_debug.txt
and
/home/faran/emc_print.txt
please tell me what should i do?
Old 01-11-2010, 05:21 AM
mauve_alert is on a distinguished road
Hello Faran. Recently I installed emc2 from source on debian, so these error messages look familiar.
Jump up and down? Usually works for me.
If jumping doesn't do it for you, did you do a setuid root? Because the first message you get after starting it says:
Starting EMC2...
A quick quick check would be to go to your emc2 source dir and do a "sudo make setuid" and see if that fixes things. If not, here is a good list of instructions to help in building from source.
good luck!
Fred
Old 01-12-2010, 12:05 AM
Dear mauve_alert
thanks for your attention
but i run these commands
$ cd src
$ ./configure --enable-run-in-place
$ make
$ sudo make setuid
and after build successfully, when i run emc i gave those errors
in addition, i can run it without any problem in simulator mode
./configure --enable-run-in-place --enable-simulator
Old 01-12-2010, 03:35 AM
Hello faran,
The "module_helper is not setuid root" message is still somewhat suspicious. Not sure if that is just a misleading error message, but best be sure and try to run emc as root (no sudo or setuid) and see if that works.
Code:
~/emc2/src/ % su -
~/emc2/src/# . scripts/emc-environment
~/emc2/src/# emc
If that still gives you the exact same errors I have a couple of questions:
  • what kernel version are you using?
  • which rtai version are you using?
  • did you build your own kernel or a prebuilt one?
  • what kind of latency do you get when you run the rtai latency test?
I ask since I am wondering if you have RTAI configured correctly ...
hope that helps,
Fred
Old 01-12-2010, 09:34 AM
Originally Posted by mauve_alert View Post
Hello faran,
Code:
~/emc2/src/ % su -
~/emc2/src/# emc
hope that helps,
Fred
Dear Fred
your guidance help me. the EMC2 runs without any problem
thanks a lot
good luck
Old 01-12-2010, 10:14 AM
Hello faran,
Glad to hear you've got it working. Was it just a matter of running it as root? Could you maybe give a short description of what it was that made it work? That way the next guy who runs into the same problem can use this information.
Anyways good luck with your working emc install!
Fred
Old 01-17-2010, 07:01 AM
Smile
Hi Fred
Sorry for delay.
yes of course, it's just for root.
I enter what you say about su
~/emc2/src/ % su -
It wanted password, but when i entered my password, it told failure
and then tried this command
sudo su
and entered may pass, and it worked!!! and then I can work as a root user. so I run emc.
again thanks for your help. really I did not know how can i run emc.
good luck
What CAM for EMC2? cwebs LinuxCNC (formerly EMC2) 7 09-02-2009 05:52 PM
Running comedi (data acquisition) with EMC2 software uoayhe LinuxCNC (formerly EMC2) 1 07-16-2009 07:51 PM
Having trouble running keling 4030 drivers with emc2 OneAndy LinuxCNC (formerly EMC2) 11 01-25-2009 07:03 PM
emc2 running a hermes engraver - video. samco LinuxCNC (formerly EMC2) 9 07-16-2008 09:40 AM
Need Help!- M8 still not being red by EMC2 SpeedsCustom LinuxCNC (formerly EMC2) 27 04-13-2008 03:36 PM
