Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 12-02-2009, 07:38 AM
harshasunder is on a distinguished road
Step and direction signals
hi
Ive got a weird problem. Ive made a config file where pin7 of the parallel port is xdirection, and pin8 is xstep.When i test using the option on the next page if i press run I get pulses on my oscilloscope only from pin7(xdirection pin).If i dont press run and click the jog button my levels change on the oscilloscope from 0 to 5 depending on which side button i clicked.But I dont get the pulses from the other step pin at all.Its just dead. When i run a file from axis i get direction signals from xdirection but no step signals now, from either pin..
is there some other setting i have to change?
thanks
harsha
Old 12-02-2009, 07:53 AM
henrikw is on a distinguished road
Hi Harsha,
Welcome to the forum!
Can you post your ini and hal file?
Henrik
Old 12-02-2009, 08:28 AM
hi henrik
cant believe someone replied so fast!
here are the files--
ive only got one stepper driver up so ive only configured pins for x axis
Old 12-02-2009, 08:43 AM
Hi again Harsha,
according to your hal file, pin8 is estop-out..
try measuring pin9 for xstep
Henrik
Old 12-02-2009, 12:13 PM
hi
i got the pin wrong when i wrote my first post. pin 7 is xdirection and pin 9 is xstep. and im getting pulses on pin 7 and nothing on pin9.Sorry for the confusion. any other suggestion.if i measure pin9 im not getting any kind of signal
Old 12-02-2009, 07:29 PM
chester88 is on a distinguished road
I would bet there is a problem with the physical port probably not set up right in the BIOS.
Change pin 9 to direction and pin 7 to step. If you get step pulses on 7 and nothing on 9
then the port has a problem.
Old 12-03-2009, 12:26 AM
hi chester
thanks for your suggestion.first i tried changing pins,to just ensure nothing was wrong physically, so now im using pin1 as x direction and pin 14 as xstep, and ground is pin18 .This is what happens - I get pulses on the x direction pin in the test page and nothing on the x step pin. But while running a job i get only direction signals on the x direction pin and not the pulses.The x step pin is still dead.
if i change the connections, the same things happen, except now i get the signals on the new xdirection pin(pin 14) and nothing on pin1.
If its something wrong with the parallel port settings in the bios setup, how do i fix it?
Old 12-03-2009, 12:55 AM
Ok I now don't think there is anything wrong with the paraport.
I see that your step length and step hold is very short (1 and 0).
What type of step drive are you driving? try 1000 1000 and see if a difference.
Could you post your stepconf file?
Chris M
Old 12-03-2009, 01:11 AM
hi
step drive is through a tiny24 microcontroller, where each falling edge of step pulse creates an interrupt which pulses 1 out of 4 output pins in order. and direction signal will reverse order depending on high or low..i tried l297 but think my ic was not working properly.
i changed step time and length manually to 1000, but didnt make a difference. Could the computer im using have something to do with it? im using a dell optiplex 760.
by stepper config file do you mean the .ini and .hal files?
Old 12-03-2009, 01:21 AM
I mean the stepconfig file.
It will be in /home/ yourname /emc2/configs (something like that)
It will end in .stepconf eg mymill.stepconf
hmm I must be missing something... strange problem!
Chris M
  #11   Ban this user!
Old 12-03-2009, 01:42 AM
here are the files.. i created a new config so here are their ini and hal files too.
  #12   Ban this user!
Old 12-03-2009, 02:05 AM
Your max velocity for x axis is set too low (1 mm/s)
set it higher (I tried 1000 mm /s)
Cheers Chris m
Tags
direction signals, step
How to generate fast step/direction signals amitgoradia Open Source Controller Boards 5 10-17-2008 02:58 AM
Step or Direction? ardor Viper Servo drives 3 07-25-2007 03:04 PM
To convert Quadrature Encoder signals to Tachogenerator signals Babar General Electronics Discussion 4 02-21-2006 12:05 AM
step in what direction craftech Stepper Motors and Drives 5 10-13-2004 05:45 AM
Step and direction source pauls Gecko Drives 1 09-03-2004 07:19 AM
