Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 11-25-2009, 05:20 AM
MarcoG is on a distinguished road
Info on HAL device driver
Hi all,
I'm new to Linux and EMC2 world,so I'm very noob, but I'm very interested on using it.
I read the docs and the wiki, and I know that EMC can actually support only a limited number of IO board.
My question is: if i want to use any athor board, i have to write a real time driver for it? So the best way is to start from zero or from source code (of course in case the maker release it)?
I found a reseller selling a board that have all the functionality I need (analog output for servo, incremental encoder counter, some digital IO). He make me available a RTAI driver, can I use it directly in EMC? (in fact I know that both have a "HAL" layer, is the same?)
The question arise because I'm italian (sorry for my english), and I'm looking for an interface board from a reseller/producer in Italy or at least in Europe.
Old 11-25-2009, 07:04 PM
CalG is on a distinguished road
Marco
Post this same question here: emc-users@lists.sourceforge.net
Lot of really knowledgeable EMC2 people there.
EMC can do anything....if YOU know how.
Cheers
CalG
Old 11-26-2009, 01:58 AM
chester88 is on a distinguished road
Marco
You would need to write a driver that interfaces with EMC's HAL (which interfaces with RTAI).
Do you have information about the board you can share?
An existing RTAI driver (source code) certainly would help, as long as it is GPL licenced.
Old 11-26-2009, 03:26 AM
Thank to all for the reply.
I would like to use the PCI-8136 by ADLink.
http://www.adlinktech.com/PD/web/PD_detail.php?pid=134
In the case that I have the realtime driver (I mean the RTAI module from reseller), is possible to build an HAL component that interface between EMC and the module? Can be this a valid solution?
Being new to this world, I don't understand your last statement:
Originally Posted by chester88 View Post
Marco
This means that I can't use a non-GPL module in EMC?
Would be grateful if you could clarify me the situation.
Thanks in advance.
Marco
Old 11-26-2009, 11:15 PM
Sorry you can use whatever you want for personal use.
I was thinking if you offered your driver to be included with EMC2, then it would need to be GPL.
It would be nice if you could offer it to be included with EMC2.
Chris M
Old 12-12-2009, 11:47 AM
jmelson is on a distinguished road
Marco
Most likely, that driver is designed for data acquisition purposes, for taking multiple analog
samples at regular intervals. Probably it would not be possible to use their driver as-is
for use with EMC. It certainly could be used as a guide for the low-level code to access
the device's registers, however.
The basic mode of operation of a servo interface driver with EMC2 is like this:
1. trigger all encoder counters to simultaneously capture the encoder position.
2. read all encoder counts
(the PID routine now calculates a new velocity)
3. output velocity to whatever controls the servo amps (analog DAC, PWM, steps)
Repeat above cycle at the next SERVO_PERIOD.
Old 12-14-2009, 07:59 AM
Thanks for the reply jmelson.
I already know the basic/general servo control scheme loop, but a confirmation from another user is always welcome!
I'm waiting for the delivery of the board and the driver, for now I'm studying the driver (yet supported and developped) of the vitalsystems board, for a better understandig.
Marco
EMCO Turn 50 Lathe RS485 PC Board Device driver mazda28 General CNC (Mill and Lathe) Control Software (NC) 5 02-02-2012 02:53 PM
Multiteke PWM Driver info soulvoid Stepper Motors and Drives 4 06-09-2009 06:24 AM
Need Help!- Tecel St200 Driver, need info please. Lar45 Benchtop Machines 0 03-13-2008 12:55 PM
Tecel St200 Driver, need info Lar45 Stepper Motors and Drives 0 03-10-2008 04:26 PM
I want to write printer driver for my plotter device. bunalmis OpenSource Software 8 02-28-2006 12:31 PM
