| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
I am new to Linux but have a good backround in electronics and MS environment. I have a new Dell Studio PC and have EMC2/Ubuntu 8.04 loaded (it is dual boot with MS Windows 7). This new PC has no parallel port on the motherboard so I purchased a PCI Parallel port - NM9805CV. I cannot find a complete enough write up on this to overcome my ignorance when it comes to Linux. I found the following: http://wiki.linuxcnc.org/cgi-bin/emcinfo.pl?NetMos ====================================================== ... a ribbon cable) uses the first address listed (b800). You can then open an editor and put the addresses into the appropriate place in your .hal file. loadrt hal_parport cfg="0x378 0xc000" ... ====================================================== this at first glance looks like a good explanation. My problem is I have no idea where this .hal file is. I've looked in the file system and found some files with .hal as the extension but don't know which one to change. Can someone please enlighten me? I'm sure this can't be too complicated for those familiar with Linux. Thank you! |
| Have you read these: http://linuxcnc.org/docs/2.3/ If you can IRC #emc on irc.us.freenode.net can sometimes be useful too. |
| After much frustration and beating my head against the wall I have grown in my linux-foo! This is specific to several things but may help someone else. Given: Dell Studio Desktop PC - no parallel port on motherboard - windows 7 - one PCI slot PCI Parallel Port card - brand: For best ports connection (approx. $20) - PCI Multi I/O Controller Card - NetMos dual ports PCI NM9715CV Parallel SPP/EPP/ECP Mode hi-speed Sherline CNC package references and actions: goto - http://linuxcnc.org/docs/2.3/EMC2_Integrator_Manual.pdf and refer to page 25 for the explanation of what to do. The file to modify for the milling machine setup (in particular the Sherline Benchtop Mill (inch)) configuration is /home/sherline/emc2/configs/sherline/standard_pinout.hal Here is my file as it is now and the control is working properly. If anyone sees an error please let me know. =================================== # first load the parport driver loadrt hal_parport cfg="0x0378 0xa800" addf parport.0.read base-thread 1 addf parport.0.write base-thread -1 addf parport.1.read base-thread 1 addf parport.1.write base-thread -1 net Xstep => parport.1.pin-03-out net Xdir => parport.1.pin-02-out net Ystep => parport.1.pin-05-out net Ydir => parport.1.pin-04-out net Zstep => parport.1.pin-07-out net Zdir => parport.1.pin-06-out net Astep => parport.1.pin-09-out net Adir => parport.1.pin-08-out # create a signal for the estop loopback net estop-loop iocontrol.0.user-enable-out iocontrol.0.emc-enable-in # create signals for tool loading loopback net tool-prep-loop iocontrol.0.tool-prepare iocontrol.0.tool-prepared net tool-change-loop iocontrol.0.tool-change iocontrol.0.tool-changed ======================================================== connect to the second parallel port that comes off the header on the card. You can change this over to the other port if you figure out which port address to use. To see the port addresses use the lspci –v command in the terminal window. My address just happened to be 0xa800. Yours will probably be different. To dual boot Ubuntu and Windows 7 I read some posts on the web to resize the drive and create several new partitions. The linux partition should be formatted as ext3 and not ntfs. I created an additional partition and formatted it as ntfs to have shared space. Those are the main things that I found that helped. I may right this up more in depth later but I have some other things I need to do right now. Later! Last edited by Jadecy; 11-25-2009 at 08:39 PM. |
| I found http://linuxcnc.org/docs/2.3/EMC2_Getting_Started.pdf The most informative. Though there is valuable information in the other documents as well. Have you found the Stepconf configuration wizard application yet? It is described in the Getting Started file. |
| New Machine Build- EMC2 E-stop parallel port pinout and E-stop loop | GreenLead | LinuxCNC (formerly EMC2) | 12 | 08-03-2010 12:05 PM |
| What comes with ubuntu & EMC2? | cwebs | LinuxCNC (formerly EMC2) | 6 | 08-17-2009 04:26 PM |
| Mach3 and NetMos 9805cv Par Port woes | Konstantin | Mach Software (ArtSoft software) | 2 | 08-03-2008 08:13 PM |
| Ubuntu 6.06 & EMC2 | tenmetalman | LinuxCNC (formerly EMC2) | 19 | 10-11-2006 09:23 PM |
| New live Ubuntu 6.06 with EMC2 | samco | LinuxCNC (formerly EMC2) | 0 | 09-20-2006 09:32 AM |
