Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 11-13-2009, 12:40 AM
fahque99 is on a distinguished road
webcam edge finder?
Anyone know of any software for EMC that can use a webcam as a edge finder? I have seen it with mach3 but havent found anything for EMC yet.
Old 06-18-2010, 09:02 PM
Mechstew is on a distinguished road
Talking Webcam center finder for emc2 Ubuntu Hardy Heron
Hi, this is Mechstew! I love the EMC2 interface, and am new to milling,
and cnc control. I saw an article referring to a webcam center finder and figured it was worth a try. "After" making it, I could find no program to utilize it with EMC2 2.3.5, all of the blogs and posts i could find were also fruitless.
Having spent forty bucks on this round thing that I just finished butchering, Wal-Mart would not take it back now! I spent 2 weeks for trial and error to finally have a working 960 X 720 (pixel) window with a crosshair. I am neither a programmer nor a computer guru, I just want to make little pieces out for big pieces and this helps me to do it reliably. If you or anyone else is interested let me know and I will try to relay that information through this portal.
I am using a Logitek c300 with Ubuntu Hardy Heron, and lauch a .py file outside of EMC2 2.3.5.
P.S. I do not check my web accounts often (once/week), now its time for me to build!
Old 06-19-2010, 10:18 AM
Dan Falck is on a distinguished road
Hi Mechstew,
I am interested in what you did with the python program.
Thanks,
Dan
Old 06-20-2010, 04:39 PM
Alexthehun is on a distinguished road
Hi Mechstew,
I have been down the same path: got working webcam but no software to make use of it!
It would be great if you could share your solution!
regards
Alex
Old 06-20-2010, 05:46 PM
Talking Webcam center finder emc2 2.3.5
Hi All, I will put together the information that I have, and try to post it on Monday.
Until then, a few things to test first, with the usb webcam plugged in.
1: Open a "terminal" window, and enter the following:
xawtv -hwscan
if this package is not installed, then using a "terminal" window enter:
sudo apt-get install xawtv
, enter your login password, then follow
on screen prompts.
The xawtv -hwscan the xawtv is only used to find out the type of output
from the webcamera and if it is connected to the dev/video0 port.
2: Next, enter the following in a terminal window:
gst-launch videotestsrc ! xvideosink
A small window displaying a test pattern should be playing on the screen.
If nothing happes then the terminal window will probably tell you how to
install gstreamer.
I have read that the gts-launch command is for "testing" gstreamer
applications, which is great, since I only want to test where the location
of a hole center is in relation to the spindles center.
If the computer does not have access to the internet I will have to figure
out how to install the packages needed to run the webcamera.
You can install a windows .ini driver for a wifi connection by using the synapic package manager (SPM), listed under system, administration. Launch the SPM and search for "ndisgtk", mark the package for install, insert the Ubuntu live cd, and then apply changes in SPM. The package name is "ndisgtk", it is an interface for "ndiswrapper", ndisgtk will create a new icon(link) listed under system, administration for wireless drivers.
You will find some attached files below, the output size of the video window should match the size of the .png overlay. when first testing do not have other audio or visual elements playing, as is might be using resources you need to use for testing. I pasted the one line command series into a file named center.py, you can use any name but be sure to end it with a .py inorder to assign it a file type. Having done this, you will be able to right click the top Ubuntu panel bar in the grey area and create a new quick launch icon(button for the .py file) you may need to look at the properties of your new .py file and check the "treat as executible" so the execute option shows.
Hopefuly all is still well. You can make you own icon image for the quicklauch by using the applications/accessories/screencapture with your webcam playing.
Side Notes:
My video window can be dragged to any size and the crosshairs remain "centered", if on AV type programs are running.
My window only works at frame rates =< 10/1 fps.
I made the .png picture using Gimp, drawing the cross first, using guidelines,
then colored the remaining back ground to alpha, as the command lines I used project the webcams stream onto this alpha color region.
When all is hunky-dory, I open EMC2, then quick-launch my.py file, then right click the un-named video window seen in the lower browser-bar to select always on top, then using the lower browser-bar again, select the EMC2, to finaly use the keyboard short cuts to calibrate, then position the part.
I would not run an EMC g-code unless the video window is closed since the gst launch is "only for testing", and it could effect latency stuff.
If you run the webcam window through the terminal you will likely see a clock error iterating to infinity, but the window is still reliable and repeatable and does not lug the computer down, unlike (webcamstudio). Anyway as for myself I just want to position parts and pull splinters.
Remember to try the smaller parts then work up to the whole.
Sources:
This source started the mess.
http://noraisin.net/~jan/diary/?p=40
This source, once inverted, help finish the mess.
http://www.opensource-archive.org/sh...d.php?t=181657
Goodluck!
Mechstew
ID:	109534   Click image for larger version
Old 10-09-2010, 08:09 PM
chester88 is on a distinguished road
Check this out for something similar:
EMC Documentation Wiki: Axis Embed Video
Old 10-10-2010, 11:48 PM
lumberjack_jeff is on a distinguished road
That is really slick. Thanks Chester.
Old 10-11-2010, 08:52 PM
cyclestart is on a distinguished road
That is slick.
Now where's the Linux version of Tormach's Scan/Cad ? I'm convinced there's an existing combination of open source tools that could turn emc into a scanner, just need to find those tools.
Well...... that, plus buy a usb microscope
Anyone who says "It only goes together one way" has no imagination.
Old 10-14-2010, 11:49 PM
fullonMAC is on a distinguished road
Patch link dead
Chester88,
I'm 95% there... the link for the patch is busted (site gone extinct, I think).
[2] http://psha.org.ru/p/0001-Added-reparent.patch
Do you know where I might grab that patch or could you drop a copy on me?
Thanks,
John Adam in Libertyville
Old 10-15-2010, 01:02 PM
It seems to be back . Maybe it should be added to wiki as a file rather then a link.
  #11   Ban this user!
Old 10-18-2010, 12:34 AM
the link is dead for me too.
  #12   Ban this user!
Old 10-18-2010, 03:04 PM
kanton's Avatar
kanton is on a distinguished road
I get this on the link but I don't understand what it is or how to use it:
From 63942679046c9d5a2942c257651270090d6b30d5 Mon Sep 17 00:00:00 2001
Date: Mon, 4 Oct 2010 00:15:06 +0400
Subject: [PATCH] Added reparent
Added ability to embed into other X-window when called with -w/--window
parametere.
Signed-off-by: Pavel Shramov
camview/camview.c | 28 ++++++++++++++++++++++++++--
1 files changed, 26 insertions(+), 2 deletions(-)
diff --git a/camview/camview.c b/camview/camview.c
index e479512..228dd53 100644
--- a/camview/camview.c
+++ b/camview/camview.c
@@ -7,6 +7,8 @@
#include
#include
+#include
+#include
#include
#include
@@ -25,6 +27,7 @@ typedef struct _state_t {
char *xml_fname;
char *extra_plugin_path;
int use_gui;
+ int window_id;
GtkWindow *window;
GtkWidget *manager_frame;
@@ -194,7 +197,10 @@ on_save_menu_item_activate (GtkWidget *widget, void * user)
static void
setup_gtk (state_t *self)
- self->window = GTK_WINDOW (gtk_window_new (GTK_WINDOW_TOPLEVEL));
+ GtkWindowType type = GTK_WINDOW_TOPLEVEL;
+ if (self->window_id)
+ type = GTK_WINDOW_POPUP;
+ self->window = GTK_WINDOW (gtk_window_new (type));
gtk_window_set_title(self->window, "Camview");
gtk_window_set_resizable(self->window, TRUE);
gtk_window_set_default_size(self->window, 1000, 540);
@@ -316,6 +322,19 @@ setup_gtk (state_t *self)
gtk_widget_show_all (GTK_WIDGET (self->window));
+ if (self->window_id) {
+ Window xid = GDK_WINDOW_XID (GTK_WIDGET(self->window)->window);
+ long info[2] = { 0, 1 << 0 /*XEMBED_MAPPED*/ };
+ Display * dpy = GDK_WINDOW_XDISPLAY(GTK_WIDGET(self->window)->window);
+ Atom atom = XInternAtom(dpy, "_XEMBED_INFO", 1);
+ printf("Reparent %d (%p)\n", xid, dpy);
+ XChangeProperty(dpy, xid, atom, atom, 32, PropModeReplace, (unsigned char *)&info, 2);
+ XReparentWindow(dpy, xid, self->window_id, 0, 0);
+ XSync(dpy, 0);
+ XMapWindow(dpy, xid);
+ XSync(dpy, 0);
g_timeout_add(250, decay_fps, self);
@@ -390,6 +409,7 @@ usage()
"chains. It uses GTK+ 2.0, OpenGL, and libcamunits.\n"
"\n"
"Options:\n"
+ " -w, --window WID Embed in window with id WID\n"
" -c, --chain NAME Load chain from file NAME\n"
" --no-gui Run without a GUI. If --no-gui is specified,\n"
" then -c is required.\n"
@@ -405,11 +425,12 @@ int main (int argc, char **argv)
state_t * self = (state_t*) calloc (1, sizeof (state_t));
self->use_gui = 1;
- char *optstring = "hc:";
+ char *optstring = "hc:w:";
int c;
struct option long_opts[] = {
{ "help", no_argument, 0, 'h' },
{ "chain", required_argument, 0, 'c' },
+ { "window", required_argument, 0, 'w' },
{ "plugin-path", required_argument, 0, 'p' },
{ "no-gui", no_argument, 0, 'u' },
{ 0, 0, 0, 0 }
@@ -418,6 +439,9 @@ int main (int argc, char **argv)
while ((c = getopt_long (argc, argv, optstring, long_opts, 0)) >= 0)
switch (c) {
+ case 'w':
+ self->window_id = atoi (optarg);
+ break;
case 'c':
self->xml_fname = strdup (optarg);
break;
1.7.1
Webcam centre / edge / hole finder alan T Quickstep 20 09-07-2011 11:18 AM
My DIY Edge Finder multiplex DIY-CNC Router Table Machines 40 05-25-2010 11:46 AM
Edge Finder Ashish B CNC Machining Centers 14 09-13-2009 03:51 AM
Edge finder eggo Australia, New Zealand Club house 3 08-04-2008 10:57 AM
Has anyone used this edge finder? l u k e General Metalwork Discussion 34 03-19-2008 01:52 PM
