Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 11-12-2009, 10:36 PM
DrStein99's Avatar
DrStein99 is on a distinguished road
home command
Is there a command I can assign to a button to home an axis or all axis?
-Erich
WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
Old 11-13-2009, 03:35 PM
chester88 is on a distinguished road
Yes if you connect a button to Halui:
halui.joint.x.home
That will home axis x
Are you using stepconf for building configurations?
Do you mean connect a real button through the parallel port?
Chris
Old 11-15-2009, 11:35 AM
DrStein99's Avatar
I used stepconf at first but not using anymore. It seemed to over-write one of the files I kept having to make backups then I have like 12 backup directories. Its easier for me to edit the files myself.
That sounds like it would do the trick. I am trying to connect an external pin to via the parallel port to trigger all-axis home. As long as I have the emc pin I can code it to the button no problem, thanks.
-Erich
Newbie- Part Home vs. Machine Home Mihelich G-Code Programing 6 06-07-2009 01:56 PM
M01 command slideleft Haas Mills 4 11-20-2008 03:01 PM
G03 COMMAND HELP!! hkfanatic G-Code Programing 25 08-04-2008 03:14 PM
Home command mgirard Mach Mill 0 05-22-2007 01:30 PM
what is the same command? hop G-Code Programing 0 06-20-2006 05:24 AM
