Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 11-03-2009, 10:11 AM
DrStein99's Avatar
DrStein99 is on a distinguished road
zero axis
On Mach-3 I assigned pushbuttons to ZERO out my axis. Can EMC do this?
For example in "MACH", when I turn machine on for the day, it HOMES all three axis to the minimum limit switches. THEN, I load my part in the middle of the machine jog to the lower left corner, and ZERO my X,Y (Press on-screen buttons). I spin-down the "Z" until it touches the top of the part, and ZERO Z. Then I RUN my G-Code program.
Is there something obvious I skipped over trying to read the documents? Or must I do something else? I know in MACH there is absolute machine coordinates, and the working coordinates, which are two different systems, obviously I wouldn't want my machine to trip a soft-limit past -.05 on the "X" if I was jogging around in the middle of the table area.
WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
Old 11-03-2009, 02:28 PM
samco is on a distinguished road
I think..
I think what you are looking for is 'touch off'
http://linuxcnc.org/docs/2.3/html/gu...#cap:Touch-Off
sam
Old 11-03-2009, 11:03 PM
DrStein99's Avatar
Got it, I figured that out quickly today after fooling around - thanks for the reply.
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 06:31 AM
New Machine Build- post for 2 axis ez trak versus 3 axis ez vision tooolman G-Code Programing 0 11-28-2008 03:33 PM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
How can I coupling a stepper motor axis directly to other axis? meknik2001 Stepper Motors and Drives 4 05-08-2008 01:54 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
