| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Has anyone here succcessfully configured EMC to run the CNC4PC C6 Spindle control card? I seem to be partially there but I cannot figure out how to configure HAL to output my signal at 25kHz. Cheers, Dan |
| Dan, Here is a file that has helped others: http://cnc4pc.com/Files/EMC2.txt. Thanks, Arturo Duncan http://cnc4pc.com |
| Well, I got mine working today! The newest version of EMC has a StepConfig page for setting it up. Now, if only i could get that spindle index pulse working... This time, my attempt was on a Sherline lathe, with Geckos and a real breakout board, not on my xylotex-driven mill.
__________________ http://www.youtube.com/user/vlmarshall |
| Well, I was able to tune the system to within 10rpm of commanded speed, anywhere in my spindle's range...which brings up another question; Is it possible to set up EMC to command/wait for a belt speed change by the operator, and to use a second set of PWM settings for the lower RPM range? I wouldn't want it to do this during Constant-Surface-Speed operations that took it into the lower speeds in high range, but for turning operations in the lower third of the speed range (0-1000) it would be nice to have it suggest low range. I sure wish I could get EMC to see my spindle index pulse... it might make this easier.
| i imagine you could just program in a tool change in the g code. then it would stop, wait for you to change the belt and tell it to go again. if you had the spindle speed set right in the following section of code, everything should work ok. |
Yeah, I could just stick an M0 in there, but the second PWM table is what I was really after.
| Im trying to make my C6 card work with EMC2 also. I cant get it to work. Tried to use the info in http://cnc4pc.com/Files/EMC2.txt but EMC2 does not understand this line: setp scale.0.in 0. what am i doing wrong? could anyone post their configuration file? would be very helpful, i imagine. |
| cnc4pc C6 card and vdf | hudmut | Benchtop Machines | 2 | 10-02-2009 09:47 AM |
| CNC4PC Variable Speed Control Board | Bubba | TurboCNC | 10 | 08-07-2009 10:01 AM |
| CNC4PC C3 Index Pulse Card - Help | TravisR100 | General Electronics Discussion | 13 | 06-29-2009 07:50 PM |
| Using Flashcut CNC Spindle rotate card control to control laser power | pyroplotter | FlashCut CNC | 0 | 10-15-2007 09:46 PM |
