Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 03-17-2005, 04:13 PM
k-linkz is on a distinguished road
Exclamation EMC project 3 axes! lets get it on!!
Hi everybody,
i'm trying to start my first CNC. I have BDI 4.18 (debian) installed on my computer. i would need a control device/module (kind of like Geckodrive) for my stepper. here is my motor spec. 1.8VDC 7A 200step/rev
any advise ? i also have a transformer, 4 resistor 5ohms , 1 big capacitor, and brige for ac/dc current. Am i missing something ?
Old 03-17-2005, 11:24 PM
ViperTX is on a distinguished road
wire, ac cord, parallel port cable, breakout board/cable...what ya doing with 5 ohm resistors?....clues.....
Old 03-18-2005, 06:37 PM
re
well the 5 ohms resistor are to prevent the over heating of the motor ....
my motors are 1.67 VDC with 7Amps
6 wires (8 points) something like this :
|_W_W_|_W_W_|
|_W_W_|_W_W_|
hope you can understand my draws
Old 03-19-2005, 06:47 PM
*Registered*
ESjaavik is on a distinguished road
@K-linkz:
Buy the Geckos and put the resistors back in your drawer. The Geckos chop up the current in pieces just large enough to get the most out of your motors without overheating them. No need for current dropping resistors.
Old 03-21-2005, 12:07 AM
ok thanx for the advise.
i have a question : i went to www.geckodrive.com to have a look.
and in there spec. they say that the gecko module give 24 to 80 VDC
and 0.3 to 7 Amp
my problem is that my motor take 7Amps but the voltage is 1.67 VDC isn't it a little to
strong for my motor
second quetion i try to control one motot then with a drive (not a gecko) but the logic output wasn't good by that i mean the motor was like fighting him self. the Output was 2 by 2 ===> 1 0 1 0 ===> 0 1 1 0 ===> 0 1 0 1 ....
and i think i need 1 by 1 ===> 1 0 0 0 ====> 0 1 0 0 ===> 0 0 1 0...
what do you think ??????????? (will the gecko be able to do that )
anyways here what is written on my motor (6 wires)
superior electric
synchronous/stepping motor
type mo92-fd-310 200 oz.in.
200 step per. rev.
1.65 V. 6.8 A. DC HZ
spec. BM101025
65 *C rise class B insul.
Old 08-03-2005, 10:37 AM
daedalus is on a distinguished road
if you dont like living dangerously i would suggest you get an optoisolated breakout board for your parallel port, as you can cause some serious damage to your pc if you get a shortcircuit and dont have one.
Old 08-03-2005, 04:10 PM
DieGuy's Avatar
DieGuy is on a distinguished road
and 0.3 to 7 Amp
strong for my motor
Normally the stepper is run at 10 to 20 times the rated voltage so about 30vdc sounds about right for those motors. Look on the Gecko site for the white papers.
A very unexciting project.......... ynneb DIY-CNC Router Table Machines 21 05-25-2005 02:30 PM
Metal CNC Project tonofsteel General Metal Working Machines 14 04-28-2005 01:47 PM
University Digital Electronics Class Project. wholepair Stepper Motors and Drives 4 04-27-2005 12:49 AM
Tiny CNC mill project chuckknigh DIY-CNC Router Table Machines 11 11-19-2004 02:00 PM
Project a chain HuFlungDung OneCNC 1 05-22-2003 07:57 PM
